740_940 parts, new, rebuilt or excellent
ibs740
Year and Model: V70 2004
Been thanked: 2 times
Post by ibs740 »
Selling as a lot $750.00 Canadian, buyer pays shipping.
740/940 parts for sale
All parts fit 1991 740 B230 FT M46 or 940 B230FT, AW71 wagons and new unless stated.
Volvo factory green manuals;
TP31127/9 09.88, Body fittings, interior, climatic units
TP31788/1 940SE wiring, does others
TP32043/1 MFI LH2.4, DI Ign EZ116Z
TP31642/1 Auto trans AW70-72Lfault tracing, repair, maintenance
TP31635/1 auto trans reconditioning
Eurocodes new, fit 1991 740 wagon and ?
Superpro poly bushings, 2 sets of each;
SPF1023K
SPF1923K
SPF2013K
SPF1025-25K
SPF2012K
Suspension parts;
2 Volvo stabilizer links
2 FEQ control arm stay bush OE# 1273235
2 FEQ control arm bush
Aftermarket? Stock size front sway bar mounts
2 FEQ control arm bush, OE#1273628
Lemforder ball joint
FEQ tie rod ZF
2 FEQ tie rod outer ends
2 Rear springs wagon, Volvo
2 front springs wagon, Lesjofors OE# 1329822
Sachs clutch kit, pressure plate, disc, friction disc for M46, PN K70030-0
AW71 SKF bearing and Volvo seal
B230 water pump by LASO Germany
2 Transmission mounts AW71 generic
Turbo Garret 25 oil supply tube, Volvo
Bosch front wheel ABS sensor Girling ABS 280mm
2 Bosch O2 sensors PN 139357
2 ECUs rebuilt by ECU doctors in 2009, installed tested then kept as spares. 0 280 000 563
2 Bosch ABS modules, 0 227 400 148
2 Mann air filters C34200
4 Mann oil filters W917
SP valve shim tool new
Brakes
2 Volvo Girling ABS front caliper retainers w/ pins and boots
2 ATE sets rear pads by Pagid Germany T4114
1 set Front Girling ABS pads by PBR D1329D
1 side Front Girling ABS pads generic
2 front rotors, Girling ABS, 2 rear rotors ATE ABS all by Raybestos
