Anyway, here's the problem.
I have a 1996 850 T5, rolled about 229k km, which I bought for relatively cheap. Some paint issues, some control arm issues, and other small stuff, but nothing major. Previous 2 owners were both Volvo dealer employees, so service records seem spotless. Changed hoses (air and most vacuum), but that's as far as I've come.
I've had an intermittent CEL (lambda-light, as I've always called it) since I started the thing w/o plugging in the MAF when changing the air filter to a K/N drop-in, and that has now become a permanent thing. It doesn't worry me too much - car runs fine, doesn't use more gas than I expect, pressures are good and all of that. Still, I'd like to know what the car thinks the problem is. I expect a MAF issue.
Anyhoo - I've got an ELM327 WiFi dongle (/adapter/whatever) which doesn't seem to be able to talk to the car. I've tried the main apps out there - DashCommand, Shift, EOBD Facile - and this occurs on all of them.
All the apps connect to the WiFi thingy, so there's power. All the apps seem to search through the modes, and then no data except battery voltage shows up. In one of the apps (I think it's EOBD Facile), it asks me to select ECU, and then only shows tranny ecu. So, my question (finally) is how do I make the engine ECU talk to me, and/or what could be the problem that makes the tranny talk, but not the engine?
I don't have the diag boxes in the engine compartment (looked for them, since I was used to using them on my old T5-R), and I'm not familiar with electronics to make my own blinky thing. Also, I'd love to have the ability to read the (semi-)live data the OBD2 port can feed to these apps.
Anyone?
