any 850 What kind of jack do you carry?
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
Is there a better more compact and maybe safer jack than the OEM? I had to use mine once on a surface that wasn't real flat and firm. I got the spare on but it was scary.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Every jack than factory jack which our cars have is better and safer. :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
JRev
Year and Model: S70 20V 2.5 1998
Post by JRev »
I carry a trolley jack in the boot, would never use the factory jack as the sole time I used that in my driveway to change a tyre, it bent!
Better to have the best option as no point going for the most compact if it isn't safe when needed.
atucker1
Year and Model: 1995 850 Turbo
Has thanked: 11 times
Been thanked: 15 times
Post by atucker1 »
The 1995 850 had a jack recall. (info here http://www.motortrend.com/cars/1995/volvo/850/recalls/) nonetheless the design is not the best in the first place.
1995 850 Turbo, Sedan
1996 850 N/A, Sedan
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I try to keep a cheap, crappy, small floor jack (Buffalo brand I think) in the trunk but I have more cars than jacks. For any kind of road trip a jack and a 4-way lug wrench goes in first. A bottle jack would actually be more convenient but the last time I tried to use one it wouldn't fit under the car with a flat tire.
Ben850
Been thanked: 7 times
Post by Ben850 »
Which ever vehicle I take, this light weight aluminum floor jack comes with. Regardless, and in spite of the OEM jack.
It is low profile, mostly aluminum, and quick pump. The pole is foam covered in the lower area, and breaks down into two pieces.
About $70. on sale.
Harbor freight. Jack.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I like the jacks out of the '99 - '00 cars.
Has thanked: 1609 times
Been thanked: 4065 times
I was lost on this thread until Roberts post. The 1999 jack is great.
I also have that Pittsburg floor jack like ben850, which also rocks....or doesn't rock.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I have a 99 with the sort of half-scissor jack and I had to use it for the first time yesterday. Hated it. Is there another jack I'm not aware of that I should have?
Also, I snapped the lug wrench in half trying to loosen a stuck nut....after loosening the other four. Boy, that was not a fun couple of hours. Not going anywhere without a socket set and breaker bar ever again.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
Ben850 wrote:Which ever vehicle I take, this light weight aluminum floor jack comes with. Regardless, and in spite of the OEM jack.
About $70. on sale.
ben850, how do you get the handle from popping out of the jack? Did you cut a hole and use a nut/bolt? My handle is always popping off
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
