1997 850 - Starting issues
dejongmc
Year and Model: 2004 Volvo S80
Post by dejongmc »
Last week I was getting some gas and left my key in the ignition. When I wanted to start the car again all lights on the dashboard came on like normal, but the starter didnt crank or move at all. I had to wait for about 30 to 45 minutes because I could start the car again, luckily.
Yesterday I had the same issue at home, but this time I had the key with me. I got home, went inside and wanted to start the car again like 1h later, but no start.
I suspect the anti-theft system to be the cause of it, but I'm not sure. Everything else works and looks fine. Apparently if I wait for 30 to 60 minutes I can start the car again.
Help!
1997 850 NA Wagon - 261,000 miles - Is no longer
2004 V70 NA Wagon - Saved my life
2004 S80
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Automatic transmission?
Battery condition?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dejongmc
Post by dejongmc »
It is an automatic transmission and the battery is just a few months old.
I was able to move the transmission into Neutral even if it wouldnt start,to push the car to a parking spot.
2004 S80
misha
Post by misha »
Next time when it refuse to crank,move shifter up & down few times(from P to L)fast or just try to start in "N" position.
I think your pnp switch is the cause of the problem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
In addition the good suggestions above, I'd recommend checking the positive battery cable and terminal to make sure they are clean, tight and corrosion free. A voltage drop test from the battery to the starter would be one good place to start.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 275 times
Been thanked: 84 times
Post by hausmeister »
I had a simmilar issue recently, it was a corroded or bad contact to the switch on the starter. Just pulled and re-seated the small connector a few times + some wd40.
850 T5-R '95 auto Image
