1998 V70xc Po243 turbo wastegate solenoid "A" malfunction
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
So I',m filling up my older Cross Country...I get 20$ but it's still not full so I go back in to add another 10$ but when I come back my XC stalled out. I was like "WTF!!" Anyway I tried to start her but she stalls immediately as she starts with no CEL. After a few tries I finalyy get a DTC (P0243), the solenoid looks fine, all 3 vacuum lines look good, plug connector looks good. Anyway, I know the MAF is connected to this so I unplug the "MAF" sensor and of course she starts right up then holding idle. I never got a code for MAF until I unplugged it of course but is it the only culprit or is there an issue with with turbo waste gate solenoid? She needs some stuff, I've been trying my best to bring her back to stage 0 but money is real tight after taking an income loss of like 30%. She needs the oil cooler lines, struts all around(rear nivomats), I did frt. LCA's/LF cv axle/brakes/tires/cap-rotor,wires, plugs/oil&filter/wheel alignment/wipers frt.&rear/ect. . Anyway, any suggestions concerning the P0243 dtc?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- Year and Model: Many Volvos
- Been thanked: 76 times
For the moment I think I would ignore the code and just drive it for a bit. Overfilling the car can flood the charcoal cannister and they run like crap for the next several starts and 100 miles or so but it clears itself up and the code may clear after that.
- shiloh51933
Yeah it won't run at all w/MAF plugged into connector and my MPG's are down of course.Ozark Lee wrote:For the moment I think I would ignore the code and just drive it for a bit. Overfilling the car can flood the charcoal cannister and they run like crap for the next several starts and 100 miles or so but it clears itself up and the code may clear after that.
There's 12V at MAF plug and 5V at solenoid A plug. I've driven way over 100km already, so I'm thinking MAF is bad needing replacement.
If it won't run at all with the MAF plugged in but does run with it unplugged that is a pretty good indication that the MAF is bad. You can try to clean it but if it is that bad it likely won't work. If you do clean it just spray the cleaner on and let it dry. Don't scrub it or even touch it.
- shiloh51933
I got my hands on a Bosch MAF sensor and like we thought the MAF was bad.. I put the MAF in and sshe runss good.Ozark Lee wrote:If it won't run at all with the MAF plugged in but does run with it unplugged that is a pretty good indication that the MAF is bad. You can try to clean it but if it is that bad it likely won't work. If you do clean it just spray the cleaner on and let it dry. Don't scrub it or even touch it.
Switchemlee
- Year and Model: 1998 v70 xc awd
I have the same exact car. I have p0243 code and my car is overboosting like crazy. Where should i start? All my hpses are good on her
Switchemlee
? Any suggestions wpuld be great
- 704 Views
Last post by JLv70t5
- 1150 Views
Last post by JerseyVince
- 776 Views
Last post by ericmci
- 286 Views
- 2969 Views
Last post by RickHaleParker
