Hello, Everyone:
I have a 1995 Volvo 940 Turbo that stalls in reverse. Here is the breakdown of what has been done so far -
1. Initial Issue from March to October is hard starts; it would take 15 minutes or more to start car; it would be longer sometimes in cold weather.
2. Car would have erratic idle after startup; car reaches operating temperature before movement; car would bog down in idle and die only in reverse; initial acceleration from takeoff is slow; car runs fine once out of first gear from takeoff; car bogs down on braking with idle lowering; sometimes car stalls at braking; gas is sometimes tapped slightly to stop stalling.
3. Issue of hard start would be intermittent; it would be less prominent in hot weather and more prominent in cold weather.
4. Sometimes in rain or wet weather, car would stall and sometimes backfire; Distributor Cap is normally changed.
5. By October, a no-start condition occurs.
6. Car starts now, idle is not erratic; car would bog down in idle and die only in reverse; you barely tap gas to keep from dying in reverse; initial acceleration from takeoff is slow; car putts a litte; car runs fine once out of first gear from takeoff; exhaust flows strongly; takeoff slightly improves incrementally with continued operation; car bogs down on braking with idle lowering; sometimes car stalls at braking; gas is sometimes tapped slightly to stop stalling.
7. During idle or operation, sometimes coolant will boil in reservoir; toggle fan brings temp down to normal in between fan cycles; toggle fan keeps coolant temp normal in really hot weather.
The following parts have been changed and are still prominently new:
Ignition Coil
Spark Plug Wires
Spark Plugs
Distributor Cap (Intially Sealed With Sealant, Condensation Issue When Raining Causes Stalling)
Rotor Button
Condensation Cap For Distributor Cap (No Need For Sealant Now)
K&N Air Filter
Turbo Intake Hose (Original Had Disentegration In Spots)
Exhaust Manifold Gasket (With New Locking Nuts and Sealant On Manifold Side, Not Block Side)
Power Stage (Ignition Module or Ignition Stage Amplifier)
Engine Coolant Temperature Sensor
Gauge Temperature Sensor
Knock Sensor
All Vacuum Hoses
All Coolant Hoses (Including Oil Cooler Hoses)
Fuel Pressure Regulator
Oxygen Sensor
Catalytic Converter (Honeycomb In Original Rattles, Discovered Gone When Removed)
Exhaust Resonator/Central Muffler (Original Damaged By Honeycomb, Sounded Like Broken Glass, Baffles More Than Likely Clogged)
Idle Air Control Valve
Starter Solenoid (Starter Tested Good)
Power Brake Booster (Original Replaced, Failed 2 Out Of Three Brake Pedal/Vacuum Tests)
Battery
Radio Suppression Relay
Throttle Position Sensor
Fuel Filter
Timing Belt and Tensioner
Crankshaft Position Sensor (Last In Chain, Resolved No-Start For Now)
The following are checkpoints, mods, and maintenance:
1. Modded Airbox for more airflow, no codes present from OBD before or after
2. Cleaned MAF Sensor with MAF Sensor Cleaner, no codes present from OBD before or after
3. Checked EGR Valve - Diaphram not broken, free movement, appears functioning
4. Had EGR Pipe Rewelded - Pipe broke from connection to throttle body, completely sealed and functional, Minimal Carbon Removed
5. No codes from EGR temp sensor before or after
6. Checked EGR Vacuum Controller through OBD - appears functional
7. Checked Fuel Pump - Repaired frayed hot wire, sealed, pump fully functioning
8. Checked Fuel Pump Relay - Functioning
9. Properly adjusted Idle Air Speed - Steady Between 700-800 RPM
10. Checked EGR Pipe to Exhaust Manifold - Minimal Carbon Removed
11. Cleaned Throttle Body with Throttle Body Cleaner - No Soot/Carbon exiting system
12. Created Toggle with Fuse in between connection, connected to slot in fuse box, cuts off with car, slight battery drain issue before and after installation
13. Checked oil in case - oil change still new, no milky appearance suggested head issues
14. Removed and cleaned breather box - no oil deposits clogging operation
15. Checked charcoal canister - stalling in reverse happens with and without it connected
16. Checked muffler during disassembly of exhaust system - no honeycomb/debris present during testing
17. Car is at Top Dead Center - Timing
18. Fuel Injectors tested fine with OBD and Pressure present at rail
The following parts have not been changed yet:
Charcoal Box
MAF Sensor (No Codes)
EGR (No Codes)
EGR Vac Controller (No Codes)
Compressor (No A/C, issue with stalling is unrelated)
Power Steering Pump (Slight squeaking on rotation, PB Blaster in bearing area confirms, issue with stalling unrelated)
Other Issues
Slight battery drain coming from somewhere in the car, have to remove negative from battery for now
Any suggestions are greatly appreciated. Thank you!
1995 Volvo 940 Turbo Stalls In Reverse, Hesitation
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
With two people, open hood with engine running, apply brake pedal, place in reverse, apply some acceleration while the other person watches motor for any rotational movement.LDunbar wrote:1995 Volvo 940 Turbo that stalls in reverse.....Power Brake Booster
Remove vacuum hose at intake for brake booster, and plug intake hole with female rubber boot. Disconnect battery say for ten minutes, then reconnect, and drive carefully (test brake) around the block. Same test, with AMM unplugged.
Set TPS via Volvo's specs
- 990 Views
Last post by Pyrinex
- 1958 Views
Last post by Annema1
- 1412 Views
Last post by ThekurgansheaD
- 17 Replies
- 5697 Views
Last post by aaron1611
- 1797 Views
Last post by mike:
