1998 v70xc MPG difference w/bad cat &/or 02 sensor
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
6 months ago I had to get rid of my 96 850 and replaced w/98 v70xc that had some issue but ran fairly well w/good interior & exterior. Struts are shot, front was shot but I repaired/replaced & aligned, has oil leaks but I've repaired all but one oil line and it smoked upon heavy acceleration. I cleared up smoking issue(rear cam seal into dizzy cap/rotor), I had to replace MAF, turbo wastegate solenoid, plugs & wires, SAS pump, battery replaced, filters, recharge refrigerant for AC and some vacuum lines were bad. In short that is what I done so far and now I'm having an MPG issue, I mean it's bad. I'm getting about 12 mpg if I'm easy on throttle and I'm thinking cat is shot along with pre cat o2. I'm thinking all the smoking/heat killed cat and fouled up o2. I've just never seen such poor MPG's with a bad cat, I'm curios to know other Volvo enthusiast experiences with similar issues.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
12 mpg is poor, that's for sure.
First stop should probably be reading your DTCs, or have you done that already?
- S
[Sold] '97 S70 T5
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Which codes are stored in ecu?
Could be numerous things.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
With all the work you have done, depending on the order in which you did it, have you tried disconnecting the battery and resetting, then doing a relearn cycle?
as I recall, it's like this: with engine warmed up to operating temperature, disconnect battery, press brakes or touch cables together, reconnect battery, idle for one minute in park, one minute in neutral, select drive, accelerate up through gears at 1/2 to 2/3 throttle until upshift to 4th (D), cruise at light throttle for a couple miles, come to full stop. (but check around- it's been awhile since I did this) After changing MAF, IAC, O2 sensors, anything that affects A/F ratios, this is a completion step.
Current Volvos:
shiloh51933
Sommerfeldt wrote:12 mpg is poor, that's for sure.
- S
I should have listed them yes... P0172 running rich and P0131 o2 sensor low voltage. Anything else I've had I believe has been taken care of as I mentioned in my first post. I can't find any issues with vacuum hoses, she runs like a champ, the exhaust is quiet, turbo is kickin in but freeze frame states she's in open loop w/fault.
shiloh51933
FLXC90 wrote:With all the work you have done, depending on the order in which you did it, have you tried disconnecting the battery and resetting, then doing a relearn cycle?
Unfortunately this process has failed to improve my mpg issue. I just can't believe how bad the mpg's are, I know the mpg should be off but I've never seen this low mpg from a bad cat and/or o2 sensor. I do major driving daily, over 100 miles a day and this is killing my pocket!! I posted the 2 DTC codes(P0172/P0131) that are still popping after a few start ups. She's stuck in open loop , so I was thinking of swapping in a new Bosch o2(upstream) when I get paid. Thank you for your input and I'll be looking foward to any more input if you come up with any more ideas, thanks.
shiloh51933
misha wrote:Which codes are stored in ecu?
P0172/P0131
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2862 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
Your ECU runs in open loop due to low/no signal from pre cat o2 sensor. You could confirm by looking at signal with code scanner. If wiring is good and connector is clean and tight you need a new sensor. If sensor is narrow band you can measure signal at connector to confirm. If you measure 0.45 volts with engine cold, then 0.1 to 0.8 with engine hot sensor's good probably.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
shiloh51933
Sorry to say that elbow line is fairly new and mounted properly. Thanks.
