98 V70 Axle Bolt: A Cautionary Tale
- hockeyjake1997
- Year and Model: 240 1992
I recently had an experience I felt was worth sharing, as a warning. I bought my V70 in late March, and I love it! But the previous owner either didn't do his research or did't care, because lots of repairs are half-a**ed. I've reconnected missing or lazily left unhooked vacuum tubing, and still have exhaust coming out of my dipstick despite his claims to having overhauled the PCV. He also mentioned having done the brakes (which to my surprise I found to be done correctly), and when he did the brakes he apparently reused the axle nuts. On a 1300 mile road trip we took a couple weeks ago, I noticed a new minor squeak a low speeds, then I could swear it looked like my drivers side camber was wrong, when I got home I I noticed a myriad of symptoms of acute problems, a faint occasional click, a quiet squeak, steering jerking but only when cranked all the way right, and eventually found out that it was out of camber, in fact the wheel was very loose; the nut, that does not hold torque well after being used basically once, backed itself out, allowing the PA Turnpike to shake and smash my suspension, and drivetrain components on the front drivers side. The camber issue caused my innermost tire tread to wear just about to the nylon belt, and tonights investigation revealed two large chips in my hub inside the bearing assembly, which has fallen apart into separate bits (hub, inner bearings and race, and the back not held together by anything but the pressure of the cv axle and wheel), and some CV axle play that may lead to it needing to be replaced. Maybe I'm just on a rant here but if theres anything to get out of this story, don't reuse parts that aren't meant to be reused.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I can't figure that one out either.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
precopster
- Year and Model: Lots
- Been thanked: 128 times
It's actially a nut. And they can be re-used.
Bolts are used on 99 plus cars and are one -use.
Blockpartie
- Year and Model: ...
Don't reuse them. Several different versions of axle nuts exist, one that, IIRC was phased out, actually had to be deformed to be secure.precopster wrote:It's actially a nut. And they can be re-used.
I've seen multiple cars that had nuts come loose. Often nuts get reused multiple times / overtorqued / not torqued correctly leading to problems later on.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
So its safe to re-use the axle nuts on an 850?precopster wrote:It's actially a nut. And they can be re-used.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
I've reused the OE nuts on both cars and never had one come loose except once many years ago when an indy did the CV boots and he did not tighten the nut properly. I reuse the OE because it looks to be of much better quality than replacements I've gotten with GKN boots (which are OEM).
This is a big honking nut and 89ft lbs + 60 degrees rotation is a lot of torque.
- Has thanked: 311 times
- Been thanked: 817 times
I've reused a lot of these, no problems yet.
- 13 Replies
- 1809 Views
- 12 Replies
- 3691 Views
Last post by JimBee
- 2837 Views
Last post by Clemens
- 12 Replies
- 1742 Views
Last post by shadetree_v70
- 19 Replies
- 2862 Views
Last post by wizechatmgr
