1992 940 Idle extremely Low 100-400rpm on start
I put in 87 gas and the idle is low. Sometimes it just cuts out and I have to start again. The car has adjustable fuel pressure. Would increasing fuel pressure help the idle issue? Or is there a different system that would help me adjust the idle speed? My old 240 had a carb-style twisty adjuster for idle speed, never had a chance to play around with it though.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Bosch LH 2.4, or Rex-I/Regina system?mika wrote:idle is low.
Tech Tip - By the Volvo tech manual when fiddling around, or "Do you feel lucky?"
Adjustable Fuel Pressure Regulator, have you got a pic of this hack?
its the Bosch LH 2.4. Does the Bosch have the ICV?
Will get pic.
Will get pic.
'97 855 N/A
'97 855 N/A
