2007 XC90 3.2 AWD Anyone used a dedicated ATF flush machine?
Turbo_Boss
Year and Model: 2008 XC90 3.2AWD
Has thanked: 12 times
Been thanked: 2 times
Post by Turbo_Boss »
Hey Guys,
Have any of you has use a Flush Machine to flush your ATF fluid? I am thinking to use this method to flush the ATF on my 2007 XC90 3.2 AWD.
I know many of you have done this by yourself and I was thinking doing it myself but after checking the Movil 3309 and Toyota WS prices here in my country (Central America) it will cost less if I take the car to a dedicated oil lube Store.
A few weeks ago I took my 2007 Toyota Prado to this Oil Lube Store were they flush the ATF with Valvoline Max ATF. They put 20 quarts on the machine and I saw thru the clear hose how this machine pull out the old ATF and introduce the new ATF.
I told him that I have a Volvo and I want Movil 3309 and he says no problem that I just have to tell him when I want to do the flush and he will get the 20 quarts of Movil 3309
So here is what I will do on the XC90. I am going to do the flush, after he finish, I will drive the car for around 15 minutes to get the ATF to temperature, then he will rise the car in a car elevator and he will remove the integrated level plug in order that fluid coming out and get it to the correct level. If fluid does not come out, he will add more until it drop out. Then he will tighten the torx screw back in the integrated level plug.
Any advice with the method he will use to check the ATF fluid level?
THX,
Isaac
BTW, here are some pics when I was doing the ATF Flush on the Toyota Prado
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
There's so many mixed opinions on tranny flushing and a lot of it has to do with how many miles are on the car. If it has a lot of miles, forcing fluid could loosen harder material that could become a problem. What I've read is with older cars that have never been flushed, to drain and fill, drive, and then drain and fill again, is the safest way to change the fluid out without the risk. But other people have different opinions on it. There's a lot of threads on the forums about tranny flushing I would read those and see how you feel about it.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The flushing machine's output pressure shouldn't exceed the transmission's pump pressure. I would get some specs on both flushing machine and transmission before flushing. This is definitely a trans that can be rendered useless by a flushing machine with excessive pressure.
