Thanks,
~Phil
Hey there, PM or post with questions, payment through Paypal, US Postal money order or Western Union if you want and shipping is from 92103.
Thanks,
~Phil
My turbobricks feedback thread: http://forums.turbobricks.com/showthread.php?t=145536
My swedespeed member link: http://forums.swedespeed.com/member.php ... ki-O-Flood
850 s/v/c70 Koni & Eibach Pro-Kit Lowering Suspension Package P80 FWD
Everything is in excellent used condition. Check the build dates, 36-2013 Spetember 2013 this set up was installed recently and run low mileage… car blew a headgasket and owner gave up on it. Rebound and compression are great on all 4 shocks, all springs are in great shape. The front strut mount bushings, bearings and cap, bump stops and dust boots, flange bolt and nuts and rear shock mounts, rear rubber spring spacers and were all replaced with new with the Eibach / Koni set up. Includes all these install pieces and they are all in great shape. Koni STR.T struts and shocks are from their site “best described as semi-sporty: improving the road handling to a considerably sportier level than standard (also suitable for lowering), with an overall comfortable feel.” So this is Koni gas pressure and oil like the Sports but not adjustable, been called by other Sport on the softest setting, so which is not soft at all. Eibach Pro-Kit springs are 1.2” drop front and rear.
This set up is a great balance between comfort and performance.
Retail price on this is FCP Suspension package $760 and Eibach Pro-Kit springs $270 = $1030
$600 + shipping (that’s $430 cheaper than list price)
img]http://i1137.photobucket.com/albums/n51 ... FWD_21.jpg[/img]
P80 IPD Ignition Upgrade Kit: IPD / MSD Ignition Coil, IPD Performance Spark Plug Wire Set, Bosch OEM Cap & Rotor
IPD Ignition Upgrade Kit: performance ignition coil restores lost power from old factory ignition coils and provides increased performance for highly tuned setups. Includes MSD coil (40,000 volts), ipd 8mm silicone coil wires, mounting bracket, fasteners. IPD custom spark plug wires are made with a high quality 8mm silicone jacket and feature a spiral wound core for maximum electrical efficiency. Engineered to meet and surpass OEM quality. Genuine OEM Bosch ignition distributor cap and rotor.
Everything is in excellent used condition, cap looks to be barely used and the rotor is brand new, never used. Huge improvement over the stock ignition system. Clean and ready to install.
IPD Ignition Upgrade Kit fits 850 and 70 series models from 1993-1998. Feel the Powah.
$170 + shipping ($90 cheaper than list price)
P80 850 x70 Bilstein HD Rears
Good used condition, rebound and comporession feel great.
$110 + shipping
P2 Bilstein Sports Rears. Pair for Lowered Cars
Good used condition, rebound and comporession feel great. These are the BE5-6794-H0 for lowered cars.
$150 + shipping
850 R ECU, Bosch 628
850 R ECU pulled from a running '96. Great upgrade for 850 Turbos, adds around 20HP and 2 psi boost.
$125 + shipping
850, V70 Wagon Spoiler w/ LED Brake Light
Awesome Volvo OE spoiler for your wagon, rare version with the extra brake light. Great used condition, no dents, dings or damages. LEDs are all working, and includes the light harness and the later style two piece mounting brakets with all the screws. Fits all 850s and 1st gen V70s up to 2000. Clear coat is pealing up on the top, but you were going to have to paint it anyways… or maybe you can fix the clear coat, color is metallic blue. 850R T5-R Powah!
$175 + shipping
K&N Filter, 33-2670
Great used condition. Cleaned and re-oiled, ready to install. Fits many of the cars in this thread and a couple more, turbo, non-turbo, XC, 850, x70 etc.
$20 + shipping
