Today my right turning signal started malfunctioning. Left turn works fine. I'm getting the blinking idiot light which I figured was a burned out bulb. But, when I went behind the car to see wha was going on I found out that both left and right upper brake lights were coming on along with the right turn light. All the lights were at about 25% intensity (barely lit).
Has anyone had a similar problem? I suspect the turn signal switch but really have no idea. I am not good at solving electrical problems.
98 v70 right turning signal malfunction
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
Today on the way to work I now get the right turn signal coming on when I hit the brakes. I no longer suspect the switch and am guessing I have a chaffing issue somewhere that has shorted the wires.
Is there a common spot that typically chaffs on the right side brake light wire harness? I'll start looking for the source this weekend but it would be nice to narrow it down to minimize the search.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
A lot has been on here about the wire in the tail gate hatch chaffing. It has been the cause of a few problems. See if anyone else chimes in about that could be the source.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Likely to be either
1 Chafe on the tail gate hatch point
2 Bad corroded ground on the right rear turn signal circuit. You often get multiple bulb light ups when you have a bad ground as the circuit grounds through the other bulbs, at reduced intensity.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
98's had a service action for the front bulb sockets melting. Volvo replaced the originals that used a push in bulb, 3157A, with a socket that used the the tried and proven twist bayonet bulb, 1157A.
The ground would fail and the current goes to the common ground with taillight filament and then feeds back into taillight circuit.
98v70dad
I have a 37 mile drive home so in the parking lot at work I removed the holder for the brake and turning signal on the right side and just let it hang inside the car for the ride home. No problems all the way home. When I got home I looked a little closer and found that there is a metal clip with sharp edges that holds the wires. All of the ribbed plastic wire covering had cracked and fallen off and all of the electrical tape and foam wrapping the wires had also fallen off. So I had wires rubbing against the sharp metal clip. I put on a ne piece of ribbed tubing and for now I'm OK. Easy fixand we'll see how it goes. I followed the wires and they go down and across the bottom opening of the tailgate, not into the tailgate hinge. When I mentioned upper brake light I don't mean the one in the center of the tail gate.
Anyhow thanks for the ideas. Please comment if you think you can help. I'm not convinced my quickie repair will fix it.
If the chafing had made the conductor ( shiny metal) visible I'll bet that did fixit!
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
So Jimmy -- If I still have bulbs that insert directly and are held into place with a metal pinch spring clip, then I should assume the service action was never performed and I have the old-style headlamps? Any chance Volvo would do anything about those headlamps now, especially if I am not the original purchaser?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
98v70dad
I wasn't able to find any evidence of exposed wires but I didn't look that hard. The wires were covered with goo left over from the disintegrated electrical tape and I had about 10 minutes to do a temporary repair. If the short stays gone for any length of time I'll call it permanent.abscate wrote:If the chafing had made the conductor ( shiny metal) visible I'll bet that did fixit!
I'm a design engineer and some of the details in the electrical system amaze me. A hard metal clip with sharp edges is a potential short eventually AND it cost more to make. A zip tie would have done a better job and it costs a fraction of a penny. That said nobody at Volvo asked for my opinion.
The strain relief on the tailgate area is a total fail. It nicely concentrates all the stress and bend in one place on the wire. Mine just broke again...or more accurately, the insulators all broke exposing bare copper wires.
- 2490 Views
Last post by benpineapple
- 6699 Views
Last post by Vova585
- 2395 Views
Last post by Estlander
- 8897 Views
Last post by rhubarb
- 644 Views
Last post by Ailanthus
