Hi, I want to lift my v70 2002 d5. I am thinking about putting front springs from xc70 or even whole strut asembly. Has anyone done that?
sorry for my bad english
2002 V70 lifting
Lift Your XC70 or V70
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Starting to play with this may give weird results, better don't throw the original parts if you replace them
One way to lift is to use larger tires and account for the speedometer change. Another way and perhaps the better is to put new Sachs shock absorbers. They will rise the car 1-2cm.
Front: XC70 automatic front springs, 7mm spacer on strut top, and 12mm diameter lower(out of two) shock bolt instead of 14mm. Rear 6cm specer on springs and 6cmm shock absorber extension. Front lifts 5,5m, rear 6,5cm.
If i had to do it second time, i would put xc70 manual transmision front springs and 4cm spacers in the rear.
- rudsaki
- Year and Model: 1998 S70 T5
- Has thanked: 26 times
- Been thanked: 15 times
what did you use for the spacer? I want the front of my 2004 S60 AWD to be the same height as the rear.
For my daughter's subaru, I bought these spacers from Subtle:
http://www.subtle-solutions.com/product ... cts_id=334
The only pain part is driving out the old studs and then adding their extra long ones.
Funny the make spacers for Saab, but not Volvo!
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
I didnt use spacer in the front, the ones i managed to find where 250 a piece for 12mm if i remember corectly. So i bought springs from xc, they fit v70/xc70/s80/s60 and 850 if i`m not mistaken. the lenght will be different thoug. v70 original lenght 447mm, xc automatic 504mm, xc manual 475mm. What i managed to find is thet s60 2,4D front springs are 434mm, AWD should be the same.
- rudsaki
thanks for the numbers, that will really help to search for the right spring for the increase I want. I just measured mine, tip to tip. It was 17'' which converts to 431.8 mm. Very close to the 434!
Previous Volvos
- rudsaki
That looks healthy!4gifted wrote:Here you go http://s21.postimg.org/9yfajvtbr/20150903_223717_1.jpg
here is my discrepancy front to back:
http://i12.photobucket.com/albums/a204/ ... wxlmsi.jpg
Previous Volvos
