04 s80 - specialist says don't touch ATF, but why?
volvobro
Year and Model: 2004 S80 2.5T AWD
Post by volvobro »
A Volvo specialist whom I inquired to advised me that I shouldn't drain and fill my transmission fluid, and that he's never done it to his own Volvo.
Is he crazy? I don't understand.. Has anyone heard of this before?
My 2004 s80 2.5t awd has 150,000km (93,200 miles) and I haven't touched the ATF in 9 months since I got it.
2004 S80 2.5T AWD - First car, first Volvo.
Follow my progress to stage 1 here.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Do you really want your Volvo work done by Grug the caveman? I hope he doesn't insist on a toughened windscreen in place of the laminated one. ;););)
volvobro
Post by volvobro »
Hahaha! Good point Mike. He seemed like a honest and trustworthy guy, even though his garage looks a bit run down. He claims he's never drain & filled or even touched his ATF on his 98' s70.
Anyways, that's probably going to be my next project for this week. Did a bit of digging and found a good write up here.
precopster
There are mutliple examples of the old AW 50-42LE transmission consistently achieving this however it could do much better on new fluid.
No such info/feedback on the newer AW 55-50SN transmission. If they don't get new fluid every 30-50 thousand miles depending on usage and towing they very quickly self implode and particularly in the earlier years when in a turbo car.
simonology101
Year and Model: 850 1995
Post by simonology101 »
i've read on some site specific to transmissions that you should do it every 30K. On my 850 I got it done even though others were like no don't it'll cause problems (clutch can burn?). But after I got it done, it just shifted much nicer. Before flushing it would throw the CEL Up flashing arrow. Still every once in a blue moon it'll do that.
2002 S40 Sold
1995 850 NA Daily Driver
volvobro
Post by volvobro »
6 months later and I still haven't touched my ATF. I haven't had any problems yet, but am I sitting on a time bomb here?
I have some time tonight, so I'm debating on whether I should drain & fill it and maybe mix some of the new fluid with the old fluid as a precuation.
Thoughts?
precopster
Should have been done 6 months ago :D
volvobro
Post by volvobro »
Hahaha thanks Mike, looks like I'll be busy tonight!
precopster
Haha you'll be able to tell it was overdue by the color of the fluid that comes out :D
oldironsights
Year and Model: 2001 S80
Post by oldironsights »
Ignore transmission oil & filter replacement? Really?!
Would you ignore your engine oil & filter also?
Mineral based oils break down in addition to having moisture, acids & solid particles held in suspension.
These substances not only clog filters but also migrate to other areas where they cause wear, buildup & corrosion.
Chemical composition may change over time. Compare the color & odor of new & used ATF.
Even A/C compressor oil goes bad with time.
Synthetics may fare better, but still require periodic replacement.
As much as we rely on our automatics, it is wise to maintain a conservative maintenance service schedule. 30k miles seems about right.
I don't perform a flush. I drop the pan & filter, then add the required amount to bring level to required point.
If concerned about oil left in the cooler & converter, then do a flush also. My oil stays clean enough to allow me to disregard what remains in the cooler & converter.
Changing oil & filter is faster & less costly than changing transmission.
I have been a hired wrench since 1980. While I listen to what the factory reps say, I do not always heed their advice.
Neglecting such an important component is a recommend ignored by me & should be ignored by Volvo owners also.
Care for your Volvo & be repaid in kind.
