Your 2001-2002 with auto tranny - issues?
My 2001 S60 T-5 with 119,000 miles has had no issues. I bought it in 2007 with 73,000 miles and have done two drain and fills with 12 quarts of Mobil JWS 3309 fluid each. Plus I installed an inline filter from IPD. I changed the filter at 12,000 miles per IPDs recommendation. I had the local dealership remove the stop/neutral feature soon after I bought it. I'm sure it will eventually break but I'll cross that bridge when I come to it.
waffleshill
- Year and Model: 2004 V70R, 2006 XC70
They all have issues eventually. Especially the T5 and AWD cars. It's not 'some' it's all. The early AW55 cars eat themselves (literally) when stopped in drive. That's why all highway driven cars don't have tranny issues at higher miles--they're not in traffic all the time. Get ready to get a new tranny eventually or get an M66/M56 and swap it. Might be hard to find an M66 because the M66 is designed to accommodate an angle-gear for the S60/V70R and only the late model T5 cars got the M66 FWD at least in America.
2004 V70R Mystic Silver Metallic/Nordkap M66 287,000 miles
Have you ever heard the old addage that changing the ATF can ruin an older car? Where did that "wisdom" come from?
Waffleshill: Throwing it in neutral and back would help it?? Using sport mode? My 911 stops in 2nd and never shifts to first. Does the Volvo T5 do that?
waffleshill
There was a software update to remove the feature. A dealer will be able to tell if it was done. The ATF change thing came from a lot of transmissions being toasted after a powerflush. Drain and fill only.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As mentioned above, if the owner replaced the fluid even on higher miles such as 80,000 and removed the neutral stop in time and replaced the T4 cover, then maybe the 2001-2002 transmission may last. There's is also a chance to find a car that had the transmission already replaced.
JRL
- Year and Model: Several
- Been thanked: 16 times
B4 servo not T4
- 533 Views
Last post by LastWinner67
- 1608 Views
Last post by EuroDriver
- 31 Replies
- 5745 Views
Last post by VolvoOwl98
- 11 Replies
- 2366 Views
Last post by jimmy57
- 636 Views
Last post by precopster
