87 740 GLE
87 740 GLE
just replaced headgasket, water pump, thermostat, timing belt and tensioner, coolant sensor, flushed system, oil change. At 200,987k runs great now but when i turn on the highbeam, or start the car with the high beam on and turn high beam off the car stops completely. Never had this problem before, has anyone else? changed the headlight relay in the fuse box still does the same thing. what is the problem?
- 419 Views
Last post by arnyval
- 486 Views
Last post by traderjoe777
