I replaced my coolant level sensor and at the same time installed a used bottle / tank I pulled out at a salvage yard. After replacing sensor I had no change in the tank reading.... reading low when full. I took off the tank and cleaned it out making sure float was moving.... reinstalled no change in reading......
When I push the float down the light goes off , as it returns to top light comes on....
I flipped the float over no change. When the sensor is not plugged in the light is on ..
Any tips? Thanks Left a message with FCP on the new sensor.
1999 v70 xc awd coolant level sensor
- Year and Model: Many Volvos
- Been thanked: 76 times
Too strange! The lamp on without the sensor unplugged is correct so that tells me that everything downstream from the switch is working as it should. My guess is a bad sensor but it is weird that you replaced it. Was the old sensor doing the same thing? If not I would say you just got a bad sensor.
Did you find a solution to this problem? I have a 2000 v70xc with exactly the same symptoms. Light stays on with sensor removed, light goes off when float is held down and comes on when float goes up.
Bob
Bob
jenkinskg
- Year and Model: 04 c70 hpt 98 s70 xc
- Has thanked: 1 time
bought new tank on amazon, no magnet in float, just put a magnet on the sensor so light would stay off.
Just read some s40 did not have sensor at all, maybe your tank is like mine?
2004 c70 2.3HPT, s60 2.5T
- 48745 Views
Last post by ggleavitt
- 4922 Views
Last post by ndphotonl
- 12 Replies
- 7195 Views
Last post by RickHaleParker
- 1363 Views
Last post by cuhfs
- 2711 Views
Last post by MadeInJapan
