2003 xc90 2.5 AWD Plop sounds from right front wheel
raykan
Year and Model: 1998 S70 GLT => 236K
Post by raykan »
Hi everybody,
I have a XC 90 (143.xxx) and I hear a couple of plop plop sounds from front right wheel area when I am turning to left. That's only time I hear it. it does it only on the certain angle of the turn (most sharp point of the turn).
Any recommendation/ idea?
Thank you for your time in advance.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Do you have standard sized wheels and tires?
Have someone turn the wheel through its arc of travel. First, this gives you a chance to listen, then to see if it is hitting the mudflap or anything else. Then remove the wheel and look for any shiny areas that look like something rubbed, strut housing, fender liner, hoses etc...
Current Volvos:
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
It could be wheel bearing starting to fail, strut bearing, cv joint, tie rod end..
