82 242 cold start issue; surging idle then dies.
taylor98v70xcharris
- Year and Model: V70 XC, 1998
Starting my car in the morning or anytime its cold is a real chore. I have to crank it several times (10-15) before it tries to start and when it finally does the idle surges like its hunting for an idle. Once the motor is warmed up everything smooths out and she runs perfect. Ive narrowed it down to three things: cold start injector, Thermal time switch, or CPR. Im pretty sure the thermal time switch gives the cold start injector a signal to fire, correct? Im just at a dead end and would love some input, Thanks!
jimmy57
- Been thanked: 322 times
Thermal time switch allows spray for a little more than a second and after you release key from start position the power for the heater is gone and it cools down again in a few seconds for a another attempt but the next cycle will be shorter.
CPR has almost no bearing on initial firing but can make for poor running after it starts.
One terminal of TTS is to the CSI and the other is hot from the 50 terminal for starter. The other terminal of the CSI is also from terminal 50 for starter solenoid. TTS is ground for CSI. On an 82 the CSI is also powered by a relay for hot start vapor lock purge. After starter runs for about a second the CSI is pulsed for .5 sec by the relay with an off time of .4 sec and then another .5 on, etc (times approximate from memory of training this injection system 25+ years back.
Unplug the oxygen sensor wire at firewall (single green wire on car side/black on O2 sensor side) and see how cold start behaves. There is supposed to be a switch for coolant temp above starter that will make the Lambda control unit ignore o2 sensor until coolant temp gets over 100F. If it is unplugged the car will surge initially until it warms. fuel mixture (CO) adjustment being off can also do this. Teace wiring for CSI and TTS for starting issues and then try the things listed for cold running issues.
- 746 Views
Last post by doublebug
- 5618 Views
Last post by resource
- 1909 Views
Last post by volvolugnut
- 12 Replies
- 2324 Views
- 3102 Views
Last post by nucci480
