1999 V70r Need instruction on timing belt replacement
dyyllllaaan
Year and Model: 1999 v70r
Post by dyyllllaaan »
I recently acquired a 99 v70r with 92k on it, it isn't currently running due to a bad fuel pump. After cutting a hole in the floor in order to get to the pump and replace it before firing it up I thought I'd better look at the timing belt since the car has been sitting for about 3 years. Anyway its cracked like hell so I am going to replace it but this will be my first time doing so and I am looking for some instruction. i.e. where the timing marks are, how to lock serp belt tensioner, will i need to remove the crank pulley?, and do i need a cam locking tool?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
You should be ok as long as the cam seals are not leaking. Do NOT take the cam hub loose.
This video is close. Your marks are straight up and your tensioner is different. The Helper Video has '99 V70R info in it. If not, check day 14, 16, or 17.
rspi
Post by rspi »
Other info:
1. Do not use after market parts if you can afford OEM parts.
2. If you do NOT have proof of water pump replacement, do it as well.
3. You should NOT need a cam locking tool.
4. Do the belt, both rollers and water pump.
5. No need to do any seals if they are not leaking.
dyyllllaaan
Thank you rspi I have been looking all over never thought to check youtube. anymore information like a step by step guide would be appreciated.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
I hate to sound snarky but all you need to do is look around a bit, but I'll spoon feed you! :mrgreen:
https://www.matthewsvolvosite.com/forums ... =1&t=47793
'00 S70, '04 S60 and the never ending quest for Stage Zero
