1998 V70xc. Oil/trans cooler line retainer
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I added pic of said retainer I'm having issues with. The oil cooler line popped off the other day after swapping radiator and I'm looking for another retainer/clamp that would work on my V70xc.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
DIY: 1998 S70 GLT Trans Cooler Line Rebuild for $10!
https://www.matthewsvolvosite.com/forums ... hp?t=55794
NOTE:
1. The Clip has a THICK and THIN side: the THICK side goes toward the Radiator.
2. Screw-type clamp over the metal clip and it will never come off.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I use a zip tie to secure that clip. Cheap, super easy to use, bullet proof.
shiloh51933
erikv11 wrote:I use a zip tie to secure that clip. Cheap, super easy to use, bullet proof.
Thank you for all the replies.
I ended up doing the zip ties, 3 across as to cover entire retainer.
The radiator hose clamp over the factory retainer sounds like a good idea.
Scholz
Year and Model: 1998 S70T-5
Post by Scholz »
I found using a 5$ snap ring pliers from harbor freight made it a trivial exercise. Allowed me to remove the years old clamps without deforming them. Could have reused them if I hadn't purchased new.
I used needle nose pliers the first time and couldn't get it off without ruining the clamp.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I use the cheap-o HF snap ring pliers too. They work well for opening up the clamp just enough to allow the lines to be pulled out. The picture below shows the old way that I used to do it before I realized that you only need to pry the clamp far enough to allow the lip on the clamp to clear the fitting on the radiator.
Snap ring pliers in action on the oil line clamp
shiloh51933
jreed wrote:I use the cheap-o HF snap ring pliers too. They work well for opening up the clamp just enough to allow the lines to be pulled out. The picture below shows the old way that I used to do it before I realized that you only need to pry the clamp far enough to allow the lip on the clamp to clear the fitting on the radiator.
I got snap ring pliers but I the bottom right retainer was deformed, I bent back into place best I could after paying $13 bucks for aftermarket retainer's that were made of tin foil!! Thanks guys for your contributions.
