Like a chucklehead, I pulled the radio/ECC unit out with ground on battery. Could've been that, or poking around under the seat. Who knew these things were so fincky? Sheesh. Getting "SRS-airbag service urgent" on display now. Anyone with a working DiCE / VIDA or a scanner that'll let me see where to look?
Ironically I work for a beer distributor. Can get you a case of something along the lines of:
Miller / Coors, Sam Adams, Harpoon, Smuttynose, Sierra Nevada, Blue Moon, Clown Shoes, Victory, etc etc. (anything non-Budwater or InBev) for some time on the DiCE.
I'm located in the Contoocook Valley, can drive it anywhere in Contoocook Valley, Monadnock Region, Concord or Manch-vegas.
Marc
New Hampshire: Anyone with DiCE? SRS error
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
- Has thanked: 1507 times
- Been thanked: 3824 times
Occasionally drive by that area and could bring my AUTEL 801. When is the inspection deadline??
MarcM
April. Just sick of the code and want to know what I disturbed. Priority now is a double coolant flush on it right now (Bars Flush, then a vinegar / water flush, double water flush, then replacing waterpump and timing belt/idler-tensioner). Up on ramps cooling for first drain now. No heat, wants to overheat on long hills (like Rte 202 West going up to 114 and the double hills before 1st exit to Hillsborough). Live in Antrim.
2005 S60 2.5T AWD
IPD mods:
IPD mods:
