New to the forum here but I have been reading through intensively.
Recently I changed the head gasket of my 2005 S40 2.4i non turbo. However,I did not properly lock the cam gears when taking the time belt and now they are out of sync.
I was able to find the small notches on these cams but the marking on the crank pulley has been nearly impossible to find.
So I figured I could simply find the TDC by manually rotating the crank and inserting a long rod in cylinder 1. That way I could put the belt on when the crank reaches TDC. But I am not sure if the TDC for this car is also the same as the markings. Does anybody have knowledge on this issue? Is it atleast within a reasonable degree?
Thank you
