96 Volvo 850 - Headliner repair
Brahms
Year and Model: 96 850T5 95 T5r
Has thanked: 2 times
Been thanked: 2 times
Post by Brahms »
I wrestled my headliner out this weekend. I have not bought my fabric or glue yet, and I am wondering if I should bother trying to strip the remnants of the old foam backing off the headliner board. So recommendations on that, and any recommendations on the best tan fabric would be nice. I found some headliner material at Joann's Fabric that looks okay. Also, does anyone know what the wires are for that were buried above the headliner board? They dead-end with black connectors. Thanks
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
I did strip the foam off mine it was flaky I used some really stretchy vinyl that was for airplane interiors, I wish I still had some as it was great stuff and everything would wipe off
jcdillin
Year and Model: 06 V70R
Been thanked: 3 times
Post by jcdillin »
Yes, you need to go all the way down to the headliner board, if you leave foam bits on it will just fall down in a few months.
I used a wire brush and just gently swept everything off.
I used the grey from jo-anns and I was quite happy with the material, I used 3 cans of this glue on my wagon.
http://amzn.to/1McCOrs
This is how mine looks with the joanns grey.
Brahms
Post by Brahms »
Thanks you guys. Yes that gray headliner looks pretty good. You did an excellent job on that.
I am going to follow your recommendations, and see if I can get some tan material at Jo-anns and scrape the headliner off.
jcdillin
Post by jcdillin »
Good luck! Don't forget your coupon, I was able to get my fabric 50% off with coupon.
Brahms
Post by Brahms »
Will do, thanks JC
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
I also used Joanns but went with the tan headliner material.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
My 850 sunshade fabric is falling. Does the complete panel assembly need to come out to get the sunshade out?
jcdillin
Post by jcdillin »
Nope, just have to remove the sunroof glass.
https://www.matthewsvolvosite.com/forums ... hp?p=30393
JimBee
Post by JimBee »
Thanks, jcdillin. I recalled changing out my headliner and and the whole sunroof panel (linkage was broken when I bought the car) so I had it all apart. The mint 93 I harvested from also had a very clean headliner so I changed that, too. The only part to fail so far is the sunshade.
Forgot about this great tutorial by Ozark Lee!
