So, after changing my parking brake pads, I found out my fuel pump was shot. After changing my fuel pump, I found out my battery was shot. After getting a new battery, I found the car sluggish and surging/rocking forward and back at speeds between < 30 mph (and only after the car had been driven for 10 minutes or so).
So, thinking it was the parking brake pads binding, I readjusted those and the e-brake cable.... and rotated tires while I was at it... and found out that my hood locks were stuck (but that was posted in a separate thread).
Well, I took the car out again this evening and the same behavior.
I parked the car in a parking lot and felt for heat on the back rotors. Nothing.
On the passenger front wheel, I smelt a burnt smell that was stronger the closer to the rotor I got. But the rotor itself was warm but not overly hot.
I then went around to the driver's side. It was glowing faintly orange and was throwing off a lot of heat.
A couple of further details that have me curious (though I'll probably find out some of the answers when I pull the front wheels off):
1) I was interrupted (to say the least) while readjusting the parking brakes when the car was jacked on the passenger side with a stand holding up the rear passenger side. It sat that way for a week. Since the driver's front would have been getting most (?) of the weight, is there something else I should be looking for other than a warped rotor or stuck caliper?
2) All of the rotors were kept at the last brake pad change (I'll have to see how many miles ago that was). I know that thinner rotors are even more prone to warping, but does it come on suddenly like this?
1996 850 GLT Wagon Last of the red hot rotors?
- Has thanked: 2199 times
I agree, but also check for collapsed flexi hoses to the calipers preventing the brake pressure release.
If you touch that caliper with a finger tip, there is wonderful 250 msec delay between hearing your finger tip sizzle and the pain that shoots up the ulnar nerve and then slams into your brain - saying IDIOT IDIOT IDIOT...
Healing time, three weeks
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
abscate wrote:If you touch that caliper with a finger tip, there is wonderful 250 msec delay between hearing your finger tip sizzle and the pain that shoots up the ulnar nerve and then slams into your brain - saying IDIOT IDIOT IDIOT...
A red hot rotor likely means a seized caliper, which will require a new caliper, pads, new rotor, brake fluid flush and maybe a new wheel bearing before it's all said and done...hopefully you can detach the brake line from said caliper without too much grief.
'00 S70, '04 S60 and the never ending quest for Stage Zero
Ive replaced both wheel bearings on the 1999 and I suddenly realize I had at least one frozen/hot rotor...Ill check back in the records but I wonder if this did them in? Still jealous of eriks perfect track record of no FWB replacement
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Unfortunately, I'm in THAT club too!
But no one saw and there are no pictures
And of course it was...a seized caliper
Current Volvos:
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I think it was you who patented the IR Thermometer, and for a good reason, no?FLXC90 wrote:abscate wrote:
Unfortunately, I'm in THAT club too!But no one saw and there are no pictures
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 17 Replies
- 450 Views
Last post by Krons
- 1853 Views
Last post by shiloh51933
- 17 Replies
- 4282 Views
Last post by villagepc
- 48 Replies
- 10829 Views
Last post by bmdubya1198
- 2433 Views
Last post by T64me
