Looking for 850 parts near detroit
1997Locked850t5
Year and Model: 850 t5 1997
Post by 1997Locked850t5 »
I live in Wixom and I need the following for my 1997 850 t5
Hose clamps for the plastic intake tubes from radiator/next to battery
2 Tires 205/50/16 or close to it.
Downpipe , I really want a 3", my flex pipe is leaking/exploded.
Glove box door for grey interior
Drivers side door lock part. Its hard to explain but I don't need the entire lock mechanism with the actuator. Instead I need a round plastic piece that the door lock cylinder rod fits into. The end of the cylinder(part where the keys fit into to unlock the door) has a rod that looks like this |- on the end. When the key is turned it rotates the |-. That fits into 2 round pieces of plastic that clips onto one another. In the middle of the plastic looks like |- to accept the lock cylinder shaft. Anyways, one of the plastic pieces is broke and doesn't want to clip onto the other. So that makes it all loose , now I'm only able to unlock the door with the key. I called Volvo and they said I would have to buy the entire lock with actuator. Not the route that I want to go down.
I would love to have a key fob/remote. Its setup for one but they are expensive. 80$ for a used one on eBay! I need the one with vertical buttons which only were available for the 96/97 models.
Thanks!!
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I have the hose clamps I think - not sure what you want. I have a 97 850 GLT parts car that runs great under the hood. Pics would help.
Same: can you take a picture of the actuator part you want? PM me if you want my cell and you can send it to me that way. I will have it, parts car has good door latches.
I have a glove box door, too.
