1998 S70 T5 - I've got an oil leak, can someone help identif
TrstnBrtt
Year and Model: 2006 XC9 2.5T
Post by TrstnBrtt »
Hey fellow Volvo owners, my 98 T5 has suffered from many oil leaks since I bought it, and being that I bought it as a beater to get me through school I've never really chased them down, just kept an eye on it, however I've actually started chasing them down and I didn't realize that some of them were quite easy to fix. Now I'm down to the last one, and it's on the bottom of the engine. Any ideas where it's coming from? I'm thinking oil return line. Sorry for the terrible pictures. I wasn't going to jack up the car just to take a picture of the leak, and yes it's been leaking for a LONG time.
If I paid attention to signs with little symbols I’d never find anywhere to park.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
First determine if it's dripping down from above. You can spray degreaser around that end of the engine and wipe it down. If you're sure it's coming from the bottom area, is the oil pan seal tight? Again, cleaning oil from that area, including the underside of the transmission will help to pinpoint it. If it's coming out the bottom of the bell housing that usually points to the rear main seal. If so, you have pull the transmission to replace that seal.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
My guess is rear main seal. Sorry
Have you serviced the PCV system yet?
'00 S70, '04 S60 and the never ending quest for Stage Zero
TrstnBrtt
Post by TrstnBrtt »
Thank you Jim. I'll get started and report
TrstnBrtt
Post by TrstnBrtt »
RussB wrote:My guess is rear main seal. Sorry
I did the PCV last October, I've had the same leak since before I did it. It's quite a small leak (that's admittedly going everywhere). Would a RMS leak stay that small for that long?
RussB
Post by RussB »
maybe
854T-5R
Year and Model: 1995
Post by 854T-5R »
Main seal, maybe gearbox drive shaft seals? Also check Turbo.
Here was mine.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
I had an RMS leak and still have a turbo return line leak. I THINK the RMS leak is cured, I haven't wiped down the old oil yet and the oil is now dripping from the turbo area.
I went to Walmart and got an 8 oz bottle of seal conditioner and poured it into the engine. After 3 tank fulls of gas, the leak appears to be stopped. Hurray if it is cured!
The turbo oil return leak usually comes down the rear side of the sump and sprays over everything from there back.
Quick question: can I get to and loosen the 5mm allen screws with an old allen wrench, you know, the kind that looks like an "L"? I also have yet to put the car up on jack stands to check things out on my 1995 855T, besides the oil is a real mess back there.
Thanks
Klaus
