2001 V70 2.3 T5 Signs of failure for VVT hub?
cstallman76
Year and Model: V70 T5 2.3l 2001
Post by cstallman76 »
Hi All,
I've have no experience with VVT but am concerned with some end-play in the exhaust vvt hub on my v70.
This past weekend I replaced a leaking front intake cam seal and decided to replace the exhaust at the same time. Everything went smooth and the car is buttoned back up and running like a dream. However while the timing belt was off and the cam lock tool was still anchoring the rear end of the shafts I noticed that the VVT hub had a sort of movement that I wasn't expecting. Besides the expected 3-4 tooth spring action in-line it seems to have some end-play. I have no idea if this is normal or not.
All the reading I've done around the VVT describes failure accompanied by a resonating noise coming from vibration. from bearing failure i presume? I don't have this. the car runs smooth and quiet.
I've taken a video that shows the end-play in the hub:
The big questions are:
1) is this lateral play in the gear normal?
2) if it is not normal, is it indicative of a failing hub?
3) if it's a failing hub what can I expect from the hub failing? will it just get noisy? do these ever fail catastrophically?
4) can they be rebuilt? new bearing race?
given that prices run in the $250 range and I just went through the wringer with the ETM, and associated 120k fall upkeep, I'd like to put off further "large" repairs for a couple months; plus, winter has arrived in MN so I'd rather stay inside sipping whiskey then wrenching in a blizzard…though wrenching in a blizzard with a sip close at hand may be doable… :idea:
Thanks for any thoughts or pointing me to any threads I might have failed to run down myself.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
I think it's worn. I can try to find my old hub and check how much play it has.
In my experience the whole engine resonates, because the timing gets out of sync just a bit, and it gets undetected by ECU, so it can't correct the problem. Though it was on N/A engine with VVT on intake.
cstallman76
Thanks for the reply...
"Wear" sounds better than imminent failure.
With VVT failing I would have assumed I'd get error codes related to exhaust bank cam...but it sounds like that is t true. Any mechanical test I can run on the hub? Or is the end play I'm experiencing test enough??
I'd love to know if these things can fail catastrophically. Last thing I want is a bricked engine. :(
iRenaissanceMan
Year and Model: 2010 XC70 T6
Post by iRenaissanceMan »
cstallman76 wrote:Hi All,
I have the same exact play on my xc90. Did you end up replacing? My exhaust cam js doing the same. Lookingto see if I must simply suck it up and buy a new cvvt hub. Thanks.
Has thanked: 1609 times
Been thanked: 4064 times
My 1999 has run about 20000 miles on a growling VVT HUB. IT just got worse so I'm dealing with it now
New hubs are expensive, like $360 so Im going used.
vtl
Post by vtl »
abscate wrote:My 1999 has run about 20000 miles on a growling VVT HUB. IT just got worse so I'm dealing with it now
1999 with like 200k or so, that's the quality! :) Nothing like VANOS in BMW :)
F250
Year and Model: 2007 S60 2.5T
Post by F250 »
I replaced both CVVT hubs on my daughter's '07 S60. The amount of play you have is worse than on my daughters, but not terribly. Her's was at 165K miles when I did the replacement this summer, BTW.
Here's the interesting thing. The new hubs had similar play, but it was 100% axial (in line with the shaft) and zero radial play (side-to-side at right angles with the shaft). My daughter's used hubs had virtually zero radial play, but they felt gritty when spinning the inner bushing with my finger while the hubs were off the cams. The new hubs were butter smooth, even though they did have about 0.002" axial play.
Hope the above context will help your decision-making process.
______________________________
Pete - '07 S60 2.5T, Gray FWD (Daughter's car)
My Garage includes '02 F250 7.3L Diesel w/285K, '03 Excursion 7.3L Diesel w/196K, '06 Outback Limited 2.5L w/228K, '99 4Runner 3.4L 2WD w/220K
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
My 2001 has this also, i think its design not wear. i was also shocked when i noticed it while i had the belt off about a year ago. Have you noticed any issues like "walking timing belt" or starting issues "timing"when hot?
Also i notice you have an old style VVT valve solenoid, i recently changed mine and have noticed a huge improvement to fuel economy and idling smooth.
How is the car running in 2020??
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
dono
Year and Model: 04 V70&XC70 2.5T AWD
Has thanked: 43 times
Been thanked: 6 times
Post by dono »
Video shows a worn hub in need of replacement. My 2004 v70 253k mi had similar axial play and was starting to leak oil. The new hub had ~2ml play. My only symptom was the oil leak.
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi :D
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi :D
1999 Mercedes e320 4Matic 238k mi :D
2008 Toyota Avalon XL 165k mi (meh)
