00 S70T5M Made new shift cable bushings
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Volvo Repair Database 00 S70T5M Made new shift cable bushings
Post by RussB »
The factory rubber/plastic bushing were worn out and sloppy. I made one from white Delrin, the other from some some high-strength PVC we had at work. I used 7/32" E-Clips to secure them. Adding these made a very significant difference in shifting feel and crispness.
Here's a sketch. I used an "O" drill (.316") to allow for a bit of clearance on the shift lever pins (8mm/.314" diameter)
'00 S70, '04 S60 and the never ending quest for Stage Zero
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2653 times
Been thanked: 1247 times
Post by matthew1 »
Oustanding, Russ. I'll put this in the Volvo Repair Database.
Also -> Amazon link
RussB
Post by RussB »
matthew1 wrote:Oustanding, Russ. I'll put this in the Volvo Repair Database.
Cool!
Big Will
Year and Model: 1998 V70 AWD
Post by Big Will »
Nice work Russ - always cool to see custom projects like this. So now people have used brass bushings from old Toyota Tercels, SS from Snabb, spherical bearings from Kaplhenke, and custom delrin. Pretty good range of options I'd say!
98 V70 AWD - M58 Gearbox - Beüst custome tune, 20T turbo w/angled exhaust housing, Green injectors, Öhlins Roadholding Suspension, B MAC Built Engine
RussB
Post by RussB »
Big Will wrote:Nice work Russ - always cool to see custom projects like this. So now people have used brass bushings from old Toyota Tercels, SS from Snabb, spherical bearings from Kaplhenke, and custom delrin. Pretty good range of options I'd say!
I'm curious to see how well these materials hold up to the heat. Seeing as the stock bushings are rubber & plastic, I think these will be just fine
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Awesome, thanks for posting this!
This is on my to do list for the 05' V70. I have some brass round laying around, so I think I will use that to make these.
But now I could actually make them ahead of time before I tear into it :D
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
