940T Nissen Radiator trans cooler tubes misaligned!
macs70GLT
Year and Model: S70 GLT 1998
Post by macs70GLT »
The radiator plastic tanks on my 95' 940T are leaking. I bought a replacement Nissens radiator on-line. Size appears correct, but the upper transmission cooler fitting on the new radiator is about 1" high compared to the installed radiator.
The current radiator has a metal plug in that location (for the temp sensor for Regina FI). My car is a 95' with Bosch LH 2.4 FI, no temp sensor.
Several web sites show the same configuration radiator with trans fitting up higher, also just one hole/fitting in that upper location.
Has anyone installed that radiator with misaligned trans tubes? I may release the end of tube from existing radiator to see how it sits naturally - however it's a steel tube which I don't want to preload on a fitting in a plastic radiator tank.
Appreciate any insights or experience you can offer.
Thanks!
Mike
Lars: 1988 245, 250K mi retired
Son of Lars: 1998 S70 GLT, 225K mi retired
Beast Mode: 1995 940T, 213K mi
Son's car: 1998 V70 GLT, 182K mi
Hans: 2002 Audi A4 QMT, 142K mi
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Is it possible to get the trans cooler line to reach? Maybe extend the line?
1988 Volvo 760 Turbo Wagon
macs70GLT
Post by macs70GLT »
Looks like there is another Nissens part 65538A, that does have the fittings in correct location for my car. RockAuto lists it for a 93' but not the 95 model year. I ordered it and will try installing it this weekend.
I'll report back.
Thought about trying to make this one work, but a 1" difference at the radiator end with the tubes being metal just didn't feel like a risk worth taking. Too bad they didn't use hydraulic hoses like my S70 GLT used, no fit up issues on that one ...
macs70GLT
Post by macs70GLT »
Today I installed the Nissens 65538A radiator, turns out the existing radiator was also the short one, not extending down below the mounts. Only issue I had was getting the top transmission line threaded on - might have stripped the threads a little. At first it was leaking fluid so I removed the nut to wrap teflon plumbers tape around the threaded part. All seems good so far.
The plastic plug for sensor was a challenge to get in, I used some liquid soap and a large clamp to squeeze it in, then brass wire through radiator fins for good measure. Overall not a bad job.
