New issue last couple days on 99 S70 T5 with 160K.
Had new rotors/pads a few weeks ago. Drove fine until a few days ago. New issue is when I apply the brake fairly firm or harder the steering wheel moves to the left. When you let off the brake, steering wheel recenters. Always goes to the left and to the same spot... ie like from 12 o'clock position to 11 o'clock position. Light braking, or braking a low speeds wheel does not seem to move.
Regardless of how hard you brake, wheel goes to same spot to the left everytime. Car does no pull left like it is a brake issue. Car drives straight. No front end noise.
Ball joint? Inner tie rod? Wheel moving to the same spot each time leads me to think its something worn in the front end.
Thank you in advance for your help.
1999 S70 Wheel moves when braking. Lower control arm bush Topic is solved
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Steering components and/or alignment. Lift one side of the car, leave the other on the ground, and try to wiggle the wheel holding it at 9 and 3. If you have a worn ball joint, you may be able to see the play in the joint itself. If you don't see it but you feel the wiggle, try it again on the other side - steering looseness will propagate its way across the steering system.
If you can't find a loose ball joint or tie rod, get your alignment checked. Misaligned steering on good components will still misbehave. But it seems unlikely that you'd suddenly have out-of-spec alignment without damage or wear in a steering component.
biohazrd76
- Year and Model: 1997 850R
Also check subframe bushes, a bad cv joint can also cause in-out movement. If your boots are shot, this may be the case. Replacing boot and regrease will not solve this if you have lost any of the ball bearings, which I have seen.
Vince
Vince
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
+1 on LCA bushings. Does it "steer" in corners as you brake, release? My XC90 did, now it tracks straight and true no matter how hard I stomp 'em
Current Volvos:
- 1137 Views
Last post by Archer
- 1129 Views
Last post by Ozark Lee
- 2150 Views
- 12 Replies
- 5592 Views
Last post by darrylrobert
- 25 Replies
- 5178 Views
