Virgin Volvo owner
- Djayexodus
- Year and Model: 2009 S60 2.5T Fwd
i just purchased my first Volvo last week an 09 s60 2.5t fwd which seems to have been adult owned, driven as well as well taken care of. It has 102k miles purchased from a used car lot that took it on a trade and was able to drive and check it out before they had it long enough to even detail much less hide any possible problems. I'm in love with the car 38 yrs old, not a teen, however would like to have some as much as possible added hp but w/o jeopardizing the integrity or life of the motor/ tranny, etc. Any advice for a first time Volvo owner in my shoes with 1k to 2k to invest. I purchased new set of tires and plan on tranny flush ,oil change,( possible timing belt? ), plugs. Thank you for your time and knowledge.....
2009 S60 2.5T
- JudgeRat
- Year and Model: s60 2004
- Has thanked: 3 times
Welcome to the "family"... definitely get the Timing Belt if you can't confirm that it was recently and properly done. Depending on how hard it's been driven and how well it's been maintained, you may need a new water pump soon. You are probably not far away from needing one or five coil packs as well.
"Molly" - Black 2004 2.4L i5 (non-turbo) T5 Auto FWD P2 Volvo s60 w/all options
Old-school race guy: "Brakes 1st, then steering, tires, wheels, & suspension, only then engine and drive-train. No sense making it go if you can't stop & steer properly...Safety first people!"
- Has thanked: 2857 times
- Been thanked: 1332 times
How's your Stage 0 checklist?
- Djayexodus
That's I guess what I am trying to accomplish plus some extra get up. Was just reading on another post and am curious being my first Volvo and first turbo car i am mechanically inclined for some basic work but for jobs needing to have done any suggestions on type of shop?
2009 S60 2.5T
- Djayexodus
It's not necessary to take it to a dealership is it?
2009 S60 2.5T
Oh h3ll no.
- Djayexodus
Thank you.. How much estimated should the stage 0 checklist set me back?
2009 S60 2.5T
Which items do you need?
- Been thanked: 4068 times
Keep that 2k in the bank for a year, change oil and drive it for 10,000 to confirm your feelings about the cars condition.
Pull plugs and measure compression. Replace plugs while you have them out - 25 buck job.
Once you fall in love with it, you won't mind the first 2k bill.
And - fix suspension and brakes to tip top condition FIRST. STOP before go fast. Thats for everyone else.
Welcome to the best group ever!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Normally the water pump will last until the second timing belt change, as per Volvo main dealer recommendation. If replaced, it is important to use an original Volvo part as aftermarket water pumps have proved to be particularly poorly made.
Timing belt, roller and tensioner choices range from Gates to original Volvo parts.
