My N/A 1995 850 wagon has 275k miles + and the valve stem are leaking a bit and the old thing just doesn't GO like she did when i bought it at merely 103k miles..
There is a fella selling his mis-matched 850 sedan nearby and it has a 1997 turbo engine in it with only 70k miles.
(i would need to buy his complete car, he doesn't want to sell the engine only, but the price is a reasonable deal for a decent salvage motor)
Can I replace my hi-mileage N/A engine with this younger Turbo? What about the different transmissions?
Thanks for your time!
850, take the NA out and replace with a Turbo?
woodsytf
- Year and Model: '95 855 n/a; 275k mi
hmm... well, fudge. perhaps i'm a bit naive, i imagine its a large job even if its a 1-to-1 swap, does a turbo car have a different wire harness?
i sorta want to keep the car and if i rebuild the head or replace it with a remanufactured one... i guess i wonder about my chances with rebuilt heads and gaskets, etc... i have read so many posts about leaks and such after fixing heads.
-woodsy
1995 855 275k miles
-woodsy
1995 855 275k miles
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
The trannies are the same, but the wiring is different. The 97 has SAS, yours has EGR. The turbos have traction control, yours doesn't. By the time you swap everything, it will be 2017. This question has been asked many times, and it is just not worth the effort.
Replace the valve seals, all 20 of them, a back breaking job if the head is left in the car, but doable in a weekend.
Klaus
- Has thanked: 316 times
- Been thanked: 531 times
It has been done, but it is a tremendous amount of work. The engines are so similar, yet so different at the same time.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
woodsytf wrote:My N/A 1995 850 wagon has 275k miles + and the valve stem are leaking a bit and the old thing just doesn't GO like she did when i bought it at merely 103k miles..
Compression numbers? Stage 0 done?
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
woodsytf
i have been meaning to check the compression numbers for a few weeks now... I haven't i done a compression test on my 850 THIS weekend because i spent yesterday under the hood trying to find my no-cranking problem that showed up when i wanted to run to the grocery for some coffee (i cant believe i'm out of coffee again!). anyways... my PNP was kaput, the swing/sweep arm was broken, AND it was a Volvo OEM PNP replaced two years ago....ugh!
anyhow, i'm gonna see if i can i can turn one up in the area salvage lots. and THEN it's time to check compression on the ol' 850.
i'm not gonna put a turbo in, but if my compression number are good enough, i'll see if my uncle will help rebuild the head.
-woodsy
1995 855 275k miles
-woodsy
1995 855 275k miles
Save it and fix it if you can... the miles are up there, but there's a good feeling that comes with keeping a very high mileage car on the road.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Some have but I would never do it.woodsytf wrote:Can I replace my hi-mileage N/A engine with this younger Turbo? What about the different transmissions?
The wire harness is different, ECU, etc. The transmissions are different, the clusters are different, and more. In '96 they went to a different ABS system which adds another level of complexity.
People are literally giving these cars away. I would not put myself through trying to swap/convert a NA to turbo.
woodsytf
i finally pressure tested. i'm not gonna swap in a turbo into my N/A car, but i'm probably gonna rebuild the head.
she smokes at traffic lights and while idling warm too, and the EGR valve is plugged shut. a few weeks ago i put on four new rotors & pads with two calipers, a new control arm and steering boots. transmission a few years ago, a radiator and hoses, a headliner about 5 years ago, door stays before that, shock mounts, fans inside and under the hood, belts, hoses, water-pump, vacuum hoses and related seals, half-shafts... the only thing i haven't seen is inside her block. i belong to this wagon and this wagon belongs to me now.... let's see how far we can go!
DRY RESULTS WET RESULTS
1) 170 1) 255
2) 165 2) 245
3) 175 3) 255
4) 165 4) 235
5) 125... 5) 185...
1) 170 1) 255
2) 165 2) 245
3) 175 3) 255
4) 165 4) 235
5) 125... 5) 185...
-woodsy
1995 855 275k miles
-woodsy
1995 855 275k miles
- 960 Views
Last post by durk80
- 1051 Views
Last post by natural4reelz
- 1515 Views
Last post by jonesg
- 1050 Views
Last post by Volvo S80
- 222 Views
Last post by 02V70
