Firstly, burned valves are not that common. Many Volvo white block engines will go to 500,000km and beyond with no issues. Look no further than many of our fellow members. So don't let this deter you from making a purchase. Until a root cause is determined, use premium fuel.
Hopefully, our moderators can sticky this and we can get some good data input.
For all members who've experienced this failure mode, can you please provide the following:
a) Year
b) Model
c) Mileage Total
d) Mileage under your ownership
e) Octane Gas you typically use
f) Supplier of Gas
g) Driving Cycle (% city/ % hwy)
h) Driving Behaviour (average, passive, aggressive)
i) Typical Load in Vehicle: single occupant, or multiple occupant
j) Location and Typical driving weather
k) Does the car have leaky valve guides (ie: blue smoke at start up)
l) What kind of oil do you use
m) Describe in detail how it happened: (ie: ambient temperature, throttle input, load, etc.)
n) How many valves burned and which Cylinder
o)What brand coolant do you use, when was it last changed.
p) What did you do with engine/car
Burned Valve Database DATA ONLY or a P0455 code will be set
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Has thanked: 311 times
- Been thanked: 817 times
1996
850 non-turbo
200,000
110,000
89 octane
various fuel suppliers
60/40
average
single occupant
yes, leaky valve stem seals
dino (non-synthetic) oil
driving on flat highway at steady speed and the car hiccuped, speed was probably 65 mph
cylinder 1, one exhaust valve
Zerex G-05, was at 31k and 3 years of age
pulled the head and rebuilt it
850 non-turbo
200,000
110,000
89 octane
60/40
average
single occupant
mecheng
@erik11 as the inagural poster, if I could I'd give you a donut we brought into work today.
Interesting info, as the non turbo cars use different exhaust valves (non sodium filled I believe) and they are not immune.
I added one more question: Coolant brand, as there is a theory that non Volvo coolant can cause hot spots.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Theory about Non Volvo coolant is ridiculous.There is No special coolant made particularly for Volvos.Coolant is coolant.
The only different type of coolant is g12.It have prolonged service interval than regular(blue or greeny)coolant.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
How about save the opinions, debates and interpretations for another thread, let's just collect data here?
- misha
Man asked and i answered.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mecheng
You beat me to it. Besides, let this thread prove the coolant theory right or wrong. There is already coolant thread about HOAT and such.erikv11 wrote:How about save the opinions, debates and interpretations for another thread, let's just collect data here?
Hopefully our great moderators can sticky this to gain traction.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Here's what I remember.
a) 1998
b) V70T5
c) 331,000
d) 161,000
e) 87/89
f) various
g) 10/90
h) Average
i) single with loads up to 500 lbs at times, interstate driving. I haul rocks at times.
j) N.C. all year
k) leaky valve stem(s)
l) dino extra mileage
m) on way home on interstate, noticed not running on all 5.
n) don't know how many valves burned. #3 no compression.
o) no special brand, had just replaced radiator less than 3,000 miles.
p) pulled parts and scraped the car. It burnt another vale and was running on 3 cylinders.
Shane
a) 1998
b) V70T5
c) 331,000
d) 161,000
e) 87/89
f) various
g) 10/90
h) Average
j) N.C. all year
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- Been thanked: 4063 times
Ask and Ye shall be glued....mecheng wrote:You beat me to it. Besides, let this thread prove the coolant theory right or wrong. There is already coolant thread about HOAT and such.erikv11 wrote:How about save the opinions, debates and interpretations for another thread, let's just collect data here?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
a) '98
b) V70 base, 5 speed manual trans.
c) 229,500 when valve burned
d) I bought with either 72K miles or 77 k miles on it, can't recall so figure about 150K
e) 87
f) Non major supplier
g) 80% stop and go, 20% highway
h) passive hypermiling
i) primarily single occupant but occasional double occupant
j) N.J. year round
k)No leaky valve stem seals
l) Mobil 1 10 W 30 year round -- 7,500 to 10,000 mile oil change interval
m) On highway at c. 85 mph in fourth (didn't realize I was in fourth for about five min). Spring day negotiating a moderate climb
n) 1 exhaust valve on cylinder #3
o) Don't pay too much attention to coolant brand -- G5 probably, but could have been almost anything. Don't have specific change interval
p) Scrapped engine -- replaced with used unit after my head rebuild/replacement project didn't work out so well. Car now has c. 301K miles and is in shop right now for replacement of failed internal clutch slave cylinder.
q) Believe front O2 sensor had failed gradually over time without throwing a CEL (average fuel mileage was going up and I thought it was a result of my awesome driving skills). It was not replaced as a maintenance item at 100K miles as it should have been and I lost track of actual mileage on the part. Guessing that failure mode was continual leaning out of mixture. That coupled with 87 octane wasn't helping things since a lean engine runs hot and an engine running on regular runs hotter.
e) 87
j) N.J. year round
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 14 Replies
- 4772 Views
- 60 Replies
- 21758 Views
- 12 Replies
- 2508 Views
Last post by kaneelschep
- 1130 Views
Last post by Volvo S80
- 2211 Views
Last post by goldxc70
