hesitation at high speed
Esel
Year and Model: 1997 850 GLT
Post by Esel »
I drive a 97 850GLT long distances. Over the past few months, doing around 70 mph, the car feels like it jumped out of gear for a split second before it starts pulling again. The RPM gauge doesn't move. In a hard climb it does it more often. And the check engine lights flash.
Bad vacuum? I haven't replaced any hoses.
JDS60R
Been thanked: 3 times
Post by JDS60R »
Sounds like an ignition misfire. Uphill means a load on the engine. Coil may be arcing to body , ignition wires may be arcingout or spark plugs are too old and need replacement.
Retired
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
How are the ignition parts (plugs, wires, cap rotor)?
Small vac line holes are usually more of a problem at idle, but for sure it could be something like a leak in an intercooler hose. I would check all of the hoses, those rubber parts are coming up on 20 years old. Especially the funny shaped intercooler hose near the throttle body, that one has been known to tear or when it is old and soft, collapse under boost.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
I agree, sounds more like a spark issue. How often has this happened? Has the CEL every stayed lit, rather than flash? What codes is it spitting out?
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Has thanked: 1505 times
Been thanked: 3818 times
Another vote for ignition
Coil , plug wires, cap rotor spark plugs, and check compression while you are in there
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Is this another candidate for the pinned thread?
Post by erikv11 »
Oh, that could be Robert, let's hope not ...
'06 S60 R, 197k
Not with an intermittant miss - I think this has to be something in ignition
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
With the hood open and the engine warmed up, start her up in a dark garage. Using a spray bottle, mist water over the ignition wires & the coil. Look for signs of blue flashes and arcing. It'll be dim, even with your eyes adjusted to the dark, so look carefully. If so, then it's time for new wires (OEM only) and maybe an ignition coil. Hopefully the wires aren't original......
M1 10W-30 HM
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
sleddriver wrote:...Hopefully the wires aren't original......
Why?
Mine are original and never had a hiccup with 300k+ km.
When ignition system is well maintained,when spark plugs,cap & rotor are in good shape and oem...oem wires almost never go bad.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
