98 s70 wagon cyl 4 misfire
installed new distributor cap and ran it for a while, cyl 4 is squeeky clean while the rest show evidence of spark. any ideas?
- Has thanked: 293 times
- Been thanked: 766 times
If the misfire just showed up at the same time as the cap change, I would look carefully at the #4 plug wire. Make sure it is seated well, make sure the ends are not falling apart. Are they OEM wires with a manufacturing date code?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
If the wire is not connected for example, or broken, then there would be no spark at all on the #4 plug. Unhook it and put an ohmmeter on the ends, you can see if it is broken.
No misfire before the cap swap?
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 1389 Views
Last post by petermetzger
- 1480 Views
Last post by Livens
