Would someone be able to provide or point me to instructions (preferably with photos or a video) on replacing the upstream O2 sensor in a 2001 V70 T5? Does it require raising the car?
I have found videos and instructions on many "similar" models, but I was not sure if they really matched my car.
I have the replacement sensor and special socket attachment, as well.
Thanks in advance.
David
Instructions for Replacing Upstream O2 Sensor in 2001 V70 T5
VolvoBooster
- Year and Model: 2004 Volvo S60 2.5T
Hello!
I just recently replaced an oxygen sensor on my 2004 Volvo S60 2.5T.
I got a Bosch oxygen sensor for $92 at AutoZone. This was the upstream one.
I am not sure if this is identical or close enough to your vehicle, but this is the resource (with pictures as of this posting) that helped me to be more confident in replacing the sensor:
2004 XC90 2.5T - Replacing Front O2 Sensor Step-by-Step
https://www.matthewsvolvosite.com/forums ... hp?t=49898
I did not end up using the guide. For my car, I had to remove nothing to reach the sensor. I drove the car on my ramps, (RhinoRamps) from Walmart, which I had purchased a great deal earlier. These are basically hardened, plastic platforms for each individual wheel to drive on to allow access to under the car. A jack, or even possibly two can easily replicate my setup and save you the $40 cost of the ramps. Again, I had this previously.
Anyway, I disconnected the battery as a precaution. Make sure to do this the correct Volvo way.
Procedure for disconnecting the battery (at least on my car):
All the things that you can turn off in the car, turn them off. For me that's the radio and A/C.
Take the negative off of the battery, then the positive.
Do the work.
Connect the positive.
Put the key in the ignition at position II.
Connect the negative to the terminal. Turn on the car.
Some may say it is not necessary to disconnect the battery. I simply do not know if it is or not.
Replacing the Upstream O2 Sensor
The sensor has two ends. One end I am coining the "screw-on end," which is the end with the hexagonal shape (or similar), if I am not mistaken.
The other end, coined the "connector." They have their correct names, whatever they are- this is simply for the sake of explanation of what i did.
Firstly, I located the old sensor's "screw-on end," which was next to the catalytic converter and unscrewed it with a wrench.
For the other end of the old sensor which was currently connected to the car, the "connector" end, I was able to reach in with two hands with moderate effort and unclip the sensor's connector from the car's connector. I had to to locate it, which can pose somewhat of a challenge, but once I did, I recognized it, along with the clip. I proceeded.
I then navigated down the oxygen sensor's wire and released the clamps that were holding the wire down to the car. I removed the old sensor from the car completely.
I took the new sensor and laid it on the top of the car (near the engine) and placed the respective ends next to where they would be placed in the car. These places, of course, are where I removed the old sensor's ends, respectively. Since I placed it in such I place that I may reach the screw-in portion from under the car, I got under the car and screwed it in.
As said, I also put the connector end next to where I would have to connect it to the car. I was able to clip the connector's end from the top of the car with two arms extended (uncomfortable, but doable) into the car, with care. Please be careful of the engine heat, even more especially if you have recently turned off the car.
I reconnected the battery properly, and the switch out was a success with little effort. I can confidently say this can take 30 mins and less (at least this is true for my car).
I hope this is understandable. Though I explained this it in words in this post, I often prefer explanations with pictures. Please reference the link above which has pictures.
Thank you.
Do the work.
Thank you.
- 1187 Views
Last post by Thunderbox
- 1570 Views
Last post by sleddriver
- 223 Views
Last post by saq
- 1123 Views
Last post by RickHaleParker
- 963 Views
Last post by davidisurf
