02 V70 T5... Doing a Valve job overhaul and almost back together. Please keep in mind I did not use a cam lock tool of any kind.....
VVT is on exhaust Crankshaft. I loosened the set screws on the pulley (to install cam cover) and when tightening them back to "factory settings", and the pulley mark aligns with timing cover notch (scratch on top of cover represents timing cover mark), the notches on back of cam do not align flush with the cam cover/head seam.
Also, when the "top side" of the notch on the back of the cam is flush with the cam cover/head seam, and the set screws are "factory settings" the notch is like 2 teeth off (toward the cabin) from notch on cam cover.
Thanks for the look and help!
Timing Marks Off
The vet hub is spring loaded. That's why you have to lock the camshaft then turn the center of the hub to tighten the spring then put your timing belt on. I think it's 18 teeth on the belt between the timing marks.
You can get someone to hold the exhaust cam marks straight across with a large screw driver or a drag link socket while you rotate the center of the vvt hub clockwise. I think its a t50 torx to turn the hub.
nthnnxn
- Year and Model: 2000 S70
- Has thanked: 3 times
- Been thanked: 4 times
dsharp wrote:You can get someone to hold the exhaust cam marks straight across with a large screw driver or a drag link socket while you rotate the center of the vvt hub clockwise. I think its a t50 torx to turn the hub.
Thanks!! I will try this... See how it goes
If I remember correctly, the CVVT hub is supposed to be torqued to like 80 ft lbs. You can change timing belts, etc. without the tool, but I am not sure you are going to be able to get it that tight without the tool - or at least a homemade version.
2007 XC70 w/195k/owned since new (#1)
2007 XC70 w/140k/owned since 129k (#2)
Texan in the Peoples Republic of New Jersey
- 10644 Views
Last post by vtl
- 22 Replies
- 7563 Views
- 15 Replies
- 6406 Views
Last post by wizechatmgr
- 1817 Views
Last post by ksdst1
- 19 Replies
- 1751 Views
Last post by cn90
