Air cleaner
Marty27
Year and Model: 1997 850
Post by Marty27 »
Should this be connected to something?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Yep.
One is going to the lower half of the housing in the lower left corner.The other one should go to a vacuum tree.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Marty27
Post by Marty27 »
That was very helpful, thank you. Apparently about half of the lines have be removed or relocated over the years. But my idle went from 900 RPM to 1,200. Is that normal?
misha
Post by misha »
Remove negative battery cable for 10-15 min to reset ecu.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Marty27
Post by Marty27 »
That didn't change anything.
Has thanked: 1609 times
Been thanked: 4064 times
1200 rpm isn't right. While idling idling, Pull each one off and plug both resulting holes to see which one is putting in air. Then go backwards on that hose to fault trace to find the vacuum leak. It might be the solenoid or temperature valve for the hot air system too, or just a hose or connector leak- more likely.
misha
Post by misha »
Before you connected those vacuum hoses...idle was ok?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Marty27
Post by Marty27 »
I found it. Overlooked a wiring connector on reassembly. I feel stupid.
dosbricks
Been thanked: 4 times
Post by dosbricks »
There is no stupid on this forum. These cars are like a good wife--you are always learning something new about her. :wink:
