So I took it upon myself to try and untangle the ETM cable from around the starter bracket and ended up trying to remove the black connection. I undid the screws and pried up lightly, the glue came loose and this is a crosspost I am just copy and pasting. Was hoping you guys could help me out. Thanks!
Hi everyone, I removed my white labeled ETM on my 2000 S70 GLT and found that the electrical connection was wrapped around a mount. To get it all the way out I decided to remove the black connection on the ETM. I unscrewed the two bolts and pried it up and the glue came loose and I am now stuck with this:
Question,
1.did I break it?
2.Is it salvageable?
3.How do you remove this connection correctly?
4.How can I fix it if its broken?
5.How do I test to see if it is functioning properly in the car?
I know lots of questions, any help would be appreciated, thanks guys
Black Connection Removal, Did I Break It?
ChrisatXeMODeX
- Year and Model: 2013 S60 AWD
- Been thanked: 2 times
[quote]Question,
1.did I break it?
/quote]
1. Yes
2. Yes
3. Follow the wire (about 16") until you find the connector.
4. Yes (+$50.00)
5. Now its too late since the wire is broken, but we can test the ETM for you here.
1.did I break it?
/quote]
1. Yes
2. Yes
4. Yes (+$50.00)
precopster
- Year and Model: Lots
- Been thanked: 128 times
I answered these questions in your duplicate post. I.also linked to.a thread with an example of a damaged one I repaired.
The connector you should have released is very close to the engine mount beneath the intake manifold. Pull on.the wire and you will be able to locate it.
- mnorris23
- Year and Model: 2000 S70 2.4l GLT
Thanks guy, sorry for the cross post, I got a functioning ETM from the yard and am going to try and return this as a core. I appreciate the feedback.
Car I own: 2000 Volvo S70 GLT 130k Stock with OEM replaced parts.
- 2158 Views
Last post by sleddriver
- 5255 Views
Last post by precopster
- 751 Views
Last post by GDiode
- 18 Replies
- 3303 Views
Last post by erikv11
- 703 Views
