Wanted: one subframe poly insert
zimmerdale
Year and Model: 1996 855R
Post by zimmerdale »
I installed the IPD poly inserts into my old subframe bushings before realizing that I really just need new bushings. Duh.
I destroyed the first insert in the process of removing the old bushing with a hole saw. Then I figured out a way to remove the old bushings without the hole saw method, and without destroying the poly insert. I ended up with 4 new bushings and only 3 good inserts. IPD and others only sell the inserts as a kit of 4.
On the off chance that someone has a weird situation and an extra insert, I'm looking to buy one poly subframe bushing insert. Anyone?
Thanks,
Jason
1996 855 R (red) 219k miles
1993 945 T (white) 207k miles
1993 244 (black) 264k miles
1992 244 (blue) 260k miles
1958 444 (jalopy)
