Will stock studs for stock steel wheel work on stock mag wheel?
harojs
Year and Model: 850, 1996
Post by harojs »
I changed from stock 15in steel wheels to stock 15in mag alloy 6 spoke wheel for 1996 850.
[Q] Can the stock studs for stock steel wheels be used on the mags?
They seems to fit and tighen fine - just checking.
-John
Bellevue, WA
[email protected]
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Post a picture of wheel bolt.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2199 times
Been thanked: 1852 times
+1 to what misha says. Adding to that, if you originally used the black regular 'bolt' head wheel lug bolts on steel wheel, I personally don't use them on my alloys. Reason being the steel wheels are much harder and can cause burrs or high spots on the underside of the bolt on the tapered area. When you tighten that on an alloy wheel it causes a pressure point and can damage them. I'm sure others may say go ahead, but at least I would make sure there are no burrs or high points first. AS I have winter and summer wheels, when I used steels for the winters I had a spare set of bolts. Short heads/black steel bolts for the steels (also allowed use of wheel covers) and the longer headed chrome finished lug bolts for summer/alloys
misha
Post by misha »
I asked for a picture because my 850 came from the factory with chrome wheel bolts.
There was two types of wheel bolts for these cars....long head chrome and short head regular bolt.
Both are suitable for alloys and steel wheels if they are oem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
I’ve used studs for alloys for winter steelies (OEM everything) and never had any issues but I didn’t know there were multiples lengths.
Ill probably play it safe and get the right studs next time
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
I believe the shoulder and grip length are identical, but the longer head "chrome" bolts for alloys may not fit under hubcaps on steelies or some alloys like the Argo, Cetus, and Helios wheels.
Current Volvos:
