Interesting Compression Test Experience
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
So I thought I still had a gas compression gauge but no, just a diesel comp gauge so I borrowed a loaner from my flaps and had engine warm ('95 850 T5-r). First cylinder -0, second - 0 . . . . I was getting worried but knew something had to be wrong with gauge as car just passed smog. Cylinder 3 also 0 so I returned faulty gauge and went to Harbor Freight and picked up one of their gauges. This time, I was getting readings Cold of 110 across the board and again, I knew something had to be wrong with gauge - throttle body valve was open during all testing. Fortunately, the HF kit came with an old school compression style adaptor so I had my gf crank while I pushed compression fitting tight against spark plug ports and finally got these readings of 155, 155,150,155, 160 . . . pretty even! I was relieved to say the least! I will most likely take warm readings next week but curious if anyone knows (in general) the variance between hot and cold compression test readings? Perhaps 10% higher? Thanks!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
No set percentage. Sometimes there is very little. Make sure you have a real strong battery or use some sort of jump box.
warmblood58
yea, I must say it was nice to see the final numbers with little variation
