BALL JOINT
adrianpike
- Year and Model:
PURCHASE A SHOP MANUAL. I LIKE THE HAYNES OVER THE CHILTON MYSELF.
OR JUST REMOVE THE 7 BOLTS AND BOLT IN THE NEW BALL JOINT.
-Adrian Pike, Adrian Technologies
'78 16 Valve 245DL
'78 16 Valve 245DL
I have the same problem on my 84 240 DL, Would this be a job I could do with just a wrench and gloves? Or do I need a spring tensionor? Can I avoid messing with the shocks all together and just replace the ball joints with new ones?
wojeepster
- Year and Model:
Yes you do not have to mess with the shock and spring assmembly, you can leave it on the car. You will need a ball joint seperator. There are basically two types one that looks like a large pickle fork and you hammer in to separate the joint and a lever type that you tighten a large bolt until it goes "bang" and the joint comes apart. I like the lever type but they cost more. If you are going to reuse the ball joint, tie rod, the lever type is the way to go in my book.
- 11 Replies
- 3202 Views
Last post by theWIFES_S70
- 600 Views
- 1570 Views
Last post by kahl
- 1605 Views
Last post by jimmy57
- 11 Replies
- 2363 Views
