I live in sunny Scotland and unfortunately, here, we have not had the privilege of seeing the warranty on our ETMs extended to 10 yrs/200000 miles.
So, not really fancying paying through the nose for a new ETM just because a couple of potentiometers worth 50 cents packed in, I came up with a possible solution (maybe) to get a new lease of life on my ETM.
Thanks to Don Willson's website (http://www.vexedvolvo.org/) explaining in great detail the root cause of the problem, I figured that if one could restore the contact between the wipers and the resistor film despite the groove marks left by them, then one should be able to restore their ETM to working condition.
My suggestion to achieve this is to spread the area of contact between the wipers and the resistor film by means of an appended tip to the wipers (see attached schematics), thus restoring a reliable contact between the parts. The increased contact area should also slow down the wearing process, though of course, it will not completely suppress it.
My hopes are that this fix could provide a further few thousand miles of motoring until the resistor film wears out completely and the ETM unit finally need replacing.
If you think this is fix is not realistic, you're probably right. My concerns are as follows:
1. By replacing the 4 narrow contacts by one large one, the potentiometer will rely on this only point of contact to make a reading. I reckon that the original design of 4 points of contact was made in that fashion so that between all these points of contacts, there should always be at least one with an accurate reading, thus ironing out any glitches caused by the other wipers. However, with only one point of contact, this new potentiometer could send enough glitches to the ETM
