1996 850 - Crunching sound from front
Teddy1975
Year and Model: 2007 V50
Has thanked: 1 time
Been thanked: 7 times
Post by Teddy1975 »
When ever I drive over the slightest bumps and no matter what speed, I get some crunching sound from both front wheels. Other than that, nothing really happens, so I'm not overly worried about it being serious. I'm thinking maybe it can be the plastic part on the wheel bearing arms, that is misplaced/misaligned so it rubs up against the frame. I don't have access to lift the car here at home, but planning to go visit my parents where my lifting tools are.
Is there a reason for having this plastic "lids" in place or is it simply cosmetic?
It's the plastic piece inside the red line I'm talking about. What is the correct way to install it, the flap side can either go upwards and sit towards the frame where it bolts onto it, or it can sit underneath the frame. I had to undo the arms to get the drive shafts out and put new ABS wheels on the shafts. Which was dead simple.
I know it could probably also be the struts, spring, spring seats or something completely different.
Thanks a bunch.
I am getting stuff done on the car, and the repairs are seemingly going well. Until the next thing pops up. So far, nothing too serious to ground the car. Soon I will be getting stuff ready for changing TB and SB, which will be my first, but feeling quite confident after reading and watching how-tos both here and on youtube. After that job is done, I'll be having a closer look at PCV, as it's beginning to act up a little. Blue smoke at start up and some oil escaping the oil filler cap. My guess is the oil trap is either full or close to it and some of the hoses are probably blocked up. Talked to my indy parts guy and he basically said to find a piece of lawn hose and a smaller vacuum hose for the small hose that runs to the air intake housing. Lots of info regarding PCV changes on this site and as this is a N/A, I anticipate the worst part of the job will be to remove the intake manifold using only normal handtools.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
huzzsaba
Year and Model: 2004 volvo xc90 2.5t
Post by huzzsaba »
My guess is bad spring seat or strut mount. I am replacing those on my xc90 tomorrow as it is making a crunching noise over bumps.
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
blandis
Year and Model: 99 S70 T5
Been thanked: 3 times
Post by blandis »
My guess is spring seats. I think most are putting the XC90 seats on the 850/s70. Spend the few extra bucks for Volvo seats and not aftermarket or another brand. Never had to replace them on my current s70... knock on wood.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I think it is a shield to keep salt water from drying the bushings and spraying inside the wheel well
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I always assumed the plastic covers were to keep road debris from being thrown up and cutting the axle boots, but that is just an assumption.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I agree :)
Crunchy over bumps sounds like spring seats, crunchy when turning the wheel even when the car is not moving sounds like strut mounts (= strut bearing plates). Plastic piece for some kind of debris protection, I try to keep it installed as long as possible.
FYI you don't need to be afraid of the stock P80 spring seat anymore, as long as you buy the Volvo part. About 4 or 5 years ago Volvo eliminated the old P80 part (and old part number) and now sell only one spring seat for the XC90 and the P80 cars (the 850 and 98-00 x70s). Same part number, same price, same part. They all use 30683637.
http://volvopartslisle.com/part/OEM-Vol ... pring-Seat
polskamafia mjl
Has thanked: 19 times
Post by polskamafia mjl »
erikv11 wrote:Same part number, same price, same part. They all use 30683637.
That's fantastic news!
Teddy1975
Has thanked: 1 time
Post by Teddy1975 »
Great news indeed regarding the OEM part now being the same.
However, I have checked the spring seat now, sorry for the delay, and it seems to be fine. The shock absorber needs to be replaced and I wonder if that could be the source of the crunching sound. When I push down on the wing, it creaks quite a lot from the wheel well and the car wobbles like jelly two, three times before coming to rest. I guess the crunching sound comes on impact when the strut hits the stop.
This car needs more TLC than I can afford at the moment.
