Turbo?
Nicksample99c70
Year and Model: 1999 volvo c70 2.4L
Turbo?
Post by Nicksample99c70 »
I need help iv looked around alot i get confused with the typs of v70s i have an lt convertible 2.4L turbo i want to upgrade to a bigger turbo with no internal engine mods please help i just got this thing 2 weeks ago and want to up the boost. Ps im use to driving a charger rt 5.7 hemi. The only thing i dont like about the volvo is the slow get up
RigsPGT
Year and Model: Red 99 S70 T5,
Been thanked: 2 times
Post by RigsPGT »
Sorry but you won't get a fast start out of your Volvo, 0-30 is not there but after that you should pick up quickly. You can upgrade your turbo with a 16T from a (98+) 2.3 engine and have a tune (check one of the sticky threads which has all the answers from engine to tune). Open it up with a 3" downpipe/exhaust, maybe a front mount cooler. There's a lot of things you can do to it, just have to set your goals and keep the limitations in mind.
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
JDS60R
Been thanked: 3 times
Post by JDS60R »
After making sure the car is in top running order - Search wastegate rod adjustment.
Adding extra boost at low rpm is hardest on the internals. The car should be peppy though. Remember that if the turbo is worn, the turbo controls are worn or the air/fuel sensors are out of spec it will not accelerate as new. Lack of compression and overall bad health of the motor will also drag you down.
A properly tuned lpt is peppy under 100 mph and then averages out with other cars.
Retired
