Here is how it went for me.....
I am a weekend mechanic, not an auto electrician, spark plug and oil changes are about my limits so where do I start in this super modern machine. I knew it was roughly under a pile of pipes and wires to the right end of the enginge and wanted to remove as least as possible to get to it.
It's in there somewhere
First I disconected the battery, negative lead first and then the breather box cover. Then I removed the two large wire lumes with the red locking gates attached to the left side of the air breather box and the large pipe between the breather and the top of the engine. There are a couple of other wire connectors that need removing to give you play, a bit of trial and error as you proceed. also, before you lift the box up take off the front breather pipe that is attached with the two bolts on top of the radiator. I finally fliped the whole box back out of the way holding it up with rubber strap.
So, we can now just about see the starter motor
She is looking remarkably clean in there and there are absolutely no signs of any corrosion on solenoid connections. This was not what I was hopeing for, it's looking like we are going to have to change out the starter after all.
I was going to leave it at that but thought I might as well just check tightness of nuts, which I did and which seemed tight enough. I then removed both nuts and it was still looking clean underneath them.
So, put it all back together and tightend them back up, probably tightening more than they were. I also saw another nut set back just between and above the two I had just tightened. I have no idea what this one did but tightened it and it did have a little more on it so was looser but certainly more than finger tight I would say.
That was it, I carefully put it all back together and prayed.
An hour later I hit the starter and she fired up immediately, wow, I tried again and again, stop, rest, start stop rest start etc etc, she started perfectly every time!! I took her for a run, nothing out of order, runing like she should all good and starting as she should.
So, I have no idea what part of my little foray into playing major mechanics did, all I can think of is that something was obviously not contacting.
It remains to be seen how long this fix will last but I am optimistic (hey they are Volvos, you have to be) and I will keep my $1200 in my pocket for a lot longer yet.
Will report back in a few months
