Volvo wouldn't start this morning. Still coughing on start.
Hey guys! My 1998 Volvo V70 was sitting in the driveway for about three days and this morning didn't want to start. I gave it about three tries before I began to diagnose. I inspected distributor, wires, tried to start with MAF sensor unplugged and re-seated the fuel pump relay. After doing all of this it started up with a cough. Let it run for awhile and it continues to start but doesn't sound right. About a week ago I noticed some irregularities with the idle. Approaching a stop it would drop low below 1000 and when put it park the idle was unusually high. Not sure if these are related. Let me know what I should do next....
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
See if there are any codes. That should always be your first stop. To me, it sounds like either an air leak, or you MAF is going.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Been thanked: 504 times
Put a jumper in fuel relay SOCKET terminals 15 and 87 (I posted some photos in forum).
If the symptoms go away, then you just diagnosed a bad fuel relay.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Not enough flow or pressure from the fuel pump?
Clogged fuel filter?
Fuel pressure regulator? (Could also be leaking/split vacuum line to same)
Dirty Idle Air Control (IAC) motor?
Dirty throttle plate?
Vacuum leak downstream of the MAF?
M1 10W-30 HM
M1 10W-30 HM
Thanks for the great responses. I am going to first try and jumper the fuel relay although I think I hear the pump come in position 2. If that doesn't do the trick I'll start checking the other boxes. Is the fuel filter a big job? Are these symptoms typical of a failing fuel pump? Or does a fuel pump either work/or it doesn't? Thanks guys. Car seems to start much easier when it's warmed up.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
When my pump (or actually my Volvos pump) was going out it would sometimes fail to provide pressure and tapping the fuel tank with a piece of wood or a hammer really good would get it going (ideally someone would start at the same time). This worked for a while till I replaced it. In between it worked like charm, and would usually start until the pump was in that stupid no start position again.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 24 Replies
- 3549 Views
Last post by bmdubya1198
- 24 Replies
- 5371 Views
Last post by Clemens
- 945 Views
Last post by BlackJack
- 1691 Views
Last post by 2ManyVolvos
- 3408 Views
Last post by dcarlson12
