Did that simple viscosity test few minutes ago:
Aisin is thinner. Color and smell is about same, Mobil may be a bit more saturated.
That aligns with my feeling that transmission shifts more harsh with Mobil 3309.
Screwdriver viscosity test: Mobil 3309 is not OE ATF
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
While pretty much everybody seems to agree that Aisin, Toyota Type-IV and Mobil 3309 are the same, there might be differences between them. Perhaps, they all meet the 3309 norm, however other properties might be different. I tried the Valvoline Max life (also 3309 norm) and it seemed to me thinner. I also had the Mobil 3309 and - while this is purely subjective - I felt it was shifting harder than the Toyota Type-IV (which I'm using now). However, my solenoids are not in the best shape, perhaps with better solenoids I wouldn't feel a difference.
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
I think that the screwdriver test would not be as reliable as a test where the fluids dripped through the same pinhole in the bottom of the sames shotglass-sized container that was filled to the brim with each.
Many many moons ago, I worked in the darkroom of a printing house as a summer job, shooting artwork, making color separations, and making printing plates. Ink viscosity was a big deal to the pressmen, and they had a simple system with a metal ladle that had a small hole, and a stopwatch. They would dip the metal ladle into the ink, and time how long the ink took to run out of the hole.
This might be a better low-tech viscosity testing set-up, as it will be a better test than allowing an unknown volume of oil to drip in each drop.
My "problem" with the screwdriver test is that both viscosity AND density come into play here, and there is no way to objectively measure the thickness of the oil film on the surface of the screwdriver as it is withdrawn.
The thickness of the film can be approximated by this equation (which mattered to printing plate makers, as it defined the amount of detail that could be printed with any specific ink):
t = SQRT( 2vn/pg )
where:
t = the thickness of the (ink or oil) film on the withdrawn object (the screwdriver)
v = the speed of the withdrawal from the ink or oil
n = the absolute viscosity of the ink/oil
p = the density of the liquid
g = acceleration due to gravity
(It is scary that I have not found something more interesting to fill that part of my memory in the decades since I last needed that equation...)
All things being otherwise equal, you can see that viscosity in on the top of the division, while density is on the bottom. And we know that a denser liquid will drip off faster because an equal volume will have more mass, so you can see how a denser liquid might appear to have less viscosity simply because it would drip off faster, or in larger drips. You may be looking at two fluids with identical viscosity, but different densities.
So, does the screwdriver test measure viscosity or density? It is a gestalt measure of BOTH at the same time.
If you had some graduated cylinders of the sort used in Chemistry class, and a super-accurate drug-dealer scale, you might be able to compare the weight of equal volumes of each oil, but these measurements are likely best left to someone who works in a lab every day, as there will be more variation from the scale used, and the eye-balling of the liquid level in the cylinders than anything else.
t = SQRT( 2vn/pg )
where:
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Screwdriver test is indeed imprecise, but even that shows clear difference between these two ATFs.
Also, what is more important, dumping sump of transmission and filling it with Aisin resulted in a shifts quality which I last felt when the car was bought 3.5 years ago, and it was still filled with OE ATF. This is even more important indication to me than dripping screwdriver
Mobil still can be the maker of Aisin ATF, but it's not exactly the same fluid as their 3309.
$6.9/quart @ autohausaz + free shipping.
zanzabar
- Year and Model: '07 V70, '84 245
- Has thanked: 1 time
- Been thanked: 4 times
Or you could actually look up real viscosity measurements:
Mobil 3309/ Toyota T-IV: @40C= 33 cSt; @100C = 7.1 cSt
Mobil 3324/ Toyota WS: @40C= 23 cSt; @100C = 5.3 cSt
Aisin TIV: @40C= 34.88 cSt; @100C = 7.332 cSt
Eneos Eco ATF:@40C= 27.67 cSt; @100C = 5.73 cSt
So, in other words... Aisin is not thinner.
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
- Has thanked: 1611 times
- Been thanked: 4071 times
Tribology trivia..
The screwdriver test was developed by Philips Petroleum, Shirley...
zanzabar
Has anyone tried the lower viscosity ATFs like Toyota WS/Mobil 3324? What was your experience?
I'm considering using the Eneos stuff in mine, just a single drain and fill so it'll be a mix of Eneos and 3309 - viscosity will thus be intermediate between the two... about @40C= 30 cSt; @100C = 6.3 cSt. I think this Eneos is higher quality and because of the lower viscosity I'm hopeful of better mpgs with same or better wear protection.
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
vtl
Look at the video: when a screwdriver was soaked in at the same depth, Mobil drips slower, at the same temperature. I forgot everything I've learned 15 years ago about kinematics of fluid, but this "Philips Petroleum" (c) abscate test is not far away in terms of result from a real lab test.zanzabar wrote:So, in other words... Aisin is not thinner.
zanzabar
C'mon guys. What is this, the Donald Trump school of tribology?vtl wrote:Look at the video: when a screwdriver was soaked in at the same depth, Mobil drips slower, at the same temperature. I forgot everything I've learned 15 years ago about kinematics of fluid, but this "Philips Petroleum" (c) abscate test is not far away in terms of result from a real lab test.zanzabar wrote:So, in other words... Aisin is not thinner.
Not that I am an expert in this stuff, but dripping off of a screwdriver obviously has little to do with viscosity measurements that describe a fluid's behavior inside an engine or transmission. The difference from what I gather from the googles is between kinematic viscosity (screwdriver test) and absolute viscosity (real measurement).
http://www.machinerylubrication.com/Rea ... -viscosity
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
